0 members (), 132 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#997123 01/05/2014 10:52 PM
I don't notice any back and forth movement but I can move the tie rod up and down on the ball stud. I believe the cup pieces are moving inside the housing and this is not a condition where the cups are loose to the ball itself. The following is a link to a short video clip showing the movement. Thank you for your help.
Joe
tie rod ends
1955 First Series 3100
Riding in the Passing Lane
That definitely is bad. You can take it apart & see what is worn or often the spring in it is broken. This would be a good time to change to the newer style.
1972 Chevy c10 Cheyenne Super
I agree with George, Make sure you look the ball over also, its probably chewed up also.
Just did mine and the old drivers side ball was worn oval, alot!
If the ends are rebuildable, there are repair parts kits and replacement ball-studs. The original design is safe and strong, and the original fittings are adjustable.
Of course, the newer style sealed replacement parts are just as good.
Thanks guys, I will plan on doing a rebuild or replace. I have read the tech tips and I believe the only tough part is removing the old ball-stud because it was peened in. I will probably go with the new style and will replace the drag link at the same time (it feels rough).
Joe
