6 members (55shaker, TUTS 59, TexasA&M48Truck, Otto Skorzeny, 3B, Wrenchman), 79 guests, and 0 robots.
Topics128,089
Posts1,056,010
Members48,430
#997117 01/05/2014 10:29 PM
Hi all
I have a 48 5400 2 ton coe, when I disassembled the front axle I did not find any caster shims fitted, the beam has the locating holes for them.
The shop manual says replace if fitted?
Does this mean I dont need them ? If I do, where would I locate them? any help would be appreciated
Kelvin
kelvin #997183 01/06/2014 3:08 AM
Hi Kelvin,
The factory recommended around 2 degrees of caster.
The only way to know if your axle and springs give you that caster with out shims is to measure it.
Caster is the amount that the top of the kingpin is tipped back beyond vertical. It is necessary to keep the truck from wandering and to make the steering self centering.
FYI that number is for bias ply tires, most people find 4 degrees is necessary with radial tires.
kelvin #997357 01/06/2014 9:48 PM
Hi Jim Sears
Thanks for the info, I am running bias ply tyres, so I will have to wait until I have it assembled to check it out
Im guessing that the shims would'nt be available to buy?
Thanks again
Kelvin
kelvin #997408 01/07/2014 12:54 AM
They are available new. I got my 4 degree from my local NAPA store. I believe someone has posted or could post the NAPA number for the 2 degree.
Also, they don't wear out. You should be able to find used ones easily.
