6 members (‘37ChevyPU, TUTS 59, baldeagle, Guitplayer, tclederman, Leo), 95 guests, and 2 robots.
Topics128,050
Posts1,055,674
#995428 12/29/2013 9:01 PM
I took my original 1940 3/4ton KE special out for a drive on Xmas eve and had my first roadside breakdown. It was driving well until it started to cut out (almost like a miss) and stated sputtering...I pulled over and it died on me then I had it towed home.
When I take the wire off the spark plug I cant seem to see any spark. I tried two used coils and an N.O.S. coil and none of them worked. I was playing around with a voltage tester and I started checking for power, what we found is I'm not getting power through the coil..we're getting power to the top of the top of the coil from the ignition switch when we bypass the coil form the ignition switch to the distributor the(tester doesn't seem to register any power going through the coil) I also cleaned and adjusted the points...truck turns over but doesn't run. What should I be testing and How do you test to see if a coil works??
Check resistance across the two coil terminals. Not sure how many ohms it should be, maybe somewhere around 30-40 ohms? If it reads 0 you need to buy a new one.
It is difficult to tell what you actually did when you were testing. With the ignition on, you should see full voltage at the feed to the coil. With this and the points open, you will see full voltage at the coil connection to the distributor. With the points closed you should see zero volts at the connection to the distributor.
Is there a connection to a switch on the starter?
1951 1 Ton Completed
We tested the coils and both show some response on the meter ( really don't know what setting to put the meter on because I have very little knowledge on electrical stuff.) So it must be something other than the coils..
I had that problem with my 46 1/2 ton, and after changing the coil and following all the wires,it ended up being the distributor,I had a distributor for a 56 235 engine and made it to fit my 216 and havent had a problem since.... 8 months now
changed the condenser also make sure your points aren't closed
Redryder pix
My Hotrod
Changed the condenser and replaced the rotor and it runs like a dream now...Thanks!
