3 members (Otto Skorzeny, RoadsScholar, UtahYork), 293 guests, and 4 robots.
Topics128,164
Posts1,057,079
Members48,463
I started the truck up the other day.. Had a half tank of gas. Flipped on the headlights and the turn signal indication lights, highbeam indication lights all came on and the gas gauge went down to empty.... The highbeams and turnsignals all still worked, but the indication lights were visibly on. I turned the headlights off and everything went back to normal and the gas gauge went back to a half a tank. What do you guys think the deal is?? Ever heard of this? I haven't changed any wiring.. BTW, it's a 72 Chevy C10.. Thanks!!!!
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
The best place to start is with the battery terminals and ground connections. Remove them and clean them up and you will probably solve the problem.
Fred
At least one of the lights(tail or head light) has a bad ground and is finding ground through the indicator light filaments. Best guess would be a bad ground at the rear of the truck. The bed not being grounded to the frame would cause the fuel gauge to be affected.
smokinjoe3,
Pretty weird. Does the '72 have a printed circuit board instrument panel? I'm not real sure on this, but the fuel gauge might be giving you a clue. For all those dash indicator lights to come on, they had to get power, which might have found its way through the common ground. I don't know exactly how this would work, but if the fuel gauge was powered through its grounded side, it might have swung the needle to EMPTY.
If turning on the headlights initiated the problem, it could be a lamp that lost its ground that comes on with the headlamps. This could be a taillight or a dash light.
You might do this drill again at night, then walk around the rig and hunt for a dim exterior light. Check the dash for a dim or nonexistent light too. Something is feeding power back through the system in search of a ground...it's finding it, but lighting everything else up in the process. Good luck.
Stuart
Riding in the Passing Lane
The 72 has a printed circuit. I believe it is not grouded . It has a ground wire built in the connector. You could run a test wire to the ground circuit or run an auxiliary ground wire. The ground circuit is pretty obvious, it has a screw in the copper print.
1972 Chevy c10 Cheyenne Super
Thanks for the advise guys. I'll go out and check a few things that you mentioned and let you know.
~Joe
'57 Chevy 210 (235)
'54 Chevy 3800
