0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99566 02/26/2007 2:46 PM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Hi all.....went to change the bulb in the dome light only to find there was no bulb when I took off the cover. When I put in the new bulb it came on but now I cannot turn it off. I removed the bulb. Is there something wrong with the light switch on the dash?
EB 63 burb 4x4 | | |
#99567 02/26/2007 7:53 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | eb's 63,
I would check the door switches first. If this is a suburban, aren't there a bunch of them!
If I'm not mistaken, the dome light is powered all the time, and finds ground through door switches etc to turn on.
Stuart | | |
#99568 02/27/2007 1:27 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | What atomarc said. And also twist the light switch full counter-clockwise, and full clockwise (not sure which direction turns the dome light off) | | |
#99569 02/27/2007 3:02 PM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | OK guys firstly thanks for the reply...I will be in the garage later today so I will take a very careful looksee. When I looked last week I could not see door switches and quessed that unlike my 78 ( had to replace two of them in that truck ) and 90 suburbans this 2 door 63 did not have them. I tried rotating the light switch as normal but the light did not go out. Will let you know what I find later today. Thanks again EB. | | |
#99570 02/27/2007 3:15 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | No OE switches on the doors back then, just the one on the switch-must be a bad switch or a short to ground in the wiring. Like Stuart said, they are hot alla time & ground to light up. Brian | | |
#99571 02/27/2007 4:02 PM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Thanks Brian....thought I was having a major seniors moment not being able to find the 2 door switches and tailgate switch. EB. | | |
#99572 02/27/2007 4:10 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | eb's 63, Didn't mean to cause a senior moment, although sometimes that isn't a bad thing! If you have no door switches, I wonder if the dome light is wired in a more conventional manner. This would be switched power too it , and the lamp holder itself grounded to the body...just like any other light on the truck. This might make the search easier. Stuart | | |
#99573 02/27/2007 4:58 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | No Stuart, you are correct(if still the OE light)-it is hot all the time(orange IIRC) & the ground is white (IIRC). The dome lamp is plastic so it has 2 wires. I have been toying w/installing some door switches on my burb to help the kids get in it. Brian | | |
#99574 02/27/2007 5:18 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brian, Thanks...a plastic lampholder, the nerve! Stuart | | |
#99575 02/28/2007 12:15 AM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | OK guys....sooooo.....am I hearing that the likely culprit is the light switch? It no longer cancels the power to the lamp. I do need to replace the high bean foot switch that's on the floor, it is frozen on high beam and no amount of WD 40 will loosen it. That will happen after the 2 speed W W switch install with pump and fluid holder. It never ends with this old dear...but that's the beauty when your retired!
Thanks everyone with your help and input!
EB. | | |
#99576 02/28/2007 2:49 AM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I think the light switch doesn't cancel power, it makes ground.I dont know on your model but on my 57 the PO had grounded the housing and then hooked up the light to dome (power all the time) on switch so it never shut off. There was only one wire run to it. :confused: He just left the bulb out. After I ran a ground from the light to the front terminal on the switch and put the bulb in it worked correctly.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#99577 03/03/2007 9:24 PM | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | Thanks all....I will let you know what I discover next week when I can get back in the garage.EB. | | |
