6 members (Uncles51, GRNHydra, Ponchogl, JW51, Forty9, Shardean), 58 guests, and 5 robots.
Topics128,021
Posts1,055,349
Members48,420
#99566 02/26/2007 2:46 PM
Hi all.....went to change the bulb in the dome light only to find there was no bulb when I took off the cover. When I put in the new bulb it came on but now I cannot turn it off. I removed the bulb. Is there something wrong with the light switch on the dash?
EB 63 burb 4x4
#99567 02/26/2007 7:53 PM
eb's 63,
I would check the door switches first. If this is a suburban, aren't there a bunch of them!
If I'm not mistaken, the dome light is powered all the time, and finds ground through door switches etc to turn on.
Stuart
#99568 02/27/2007 1:27 AM
What atomarc said. And also twist the light switch full counter-clockwise, and full clockwise (not sure which direction turns the dome light off)
#99569 02/27/2007 3:02 PM
OK guys firstly thanks for the reply...I will be in the garage later today so I will take a very careful looksee. When I looked last week I could not see door switches and quessed that unlike my 78 ( had to replace two of them in that truck ) and 90 suburbans this 2 door 63 did not have them. I tried rotating the light switch as normal but the light did not go out. Will let you know what I find later today.
Thanks again
EB.
#99570 02/27/2007 3:15 PM
No OE switches on the doors back then, just the one on the switch-must be a bad switch or a short to ground in the wiring. Like Stuart said, they are hot alla time & ground to light up. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#99571 02/27/2007 4:02 PM
Thanks Brian....thought I was having a major seniors moment not being able to find the 2 door switches and tailgate switch.
EB.
#99572 02/27/2007 4:10 PM
eb's 63,
Didn't mean to cause a senior moment, although sometimes that isn't a bad thing! smile
If you have no door switches, I wonder if the dome light is wired in a more conventional manner. This would be switched power too it , and the lamp holder itself grounded to the body...just like any other light on the truck. This might make the search easier.
Stuart
#99573 02/27/2007 4:58 PM
No Stuart, you are correct(if still the OE light)-it is hot all the time(orange IIRC) & the ground is white (IIRC). The dome lamp is plastic so it has 2 wires. I have been toying w/installing some door switches on my burb to help the kids get in it. Brian
#99574 02/27/2007 5:18 PM
Brian,
Thanks...a plastic lampholder, the nerve! smile
Stuart
#99575 02/28/2007 12:15 AM
OK guys....sooooo.....am I hearing that the likely culprit is the light switch? It no longer cancels the power to the lamp. I do need to replace the high bean foot switch that's on the floor, it is frozen on high beam and no amount of WD 40 will loosen it. That will happen after the 2 speed W W switch install with pump and fluid holder. It never ends with this old dear...but that's the beauty when your retired!
Thanks everyone with your help and input!
EB.
#99576 02/28/2007 2:49 AM
I think the light switch doesn't cancel power, it makes ground.I dont know on your model but on my 57 the PO had grounded the housing and then hooked up the light to dome (power all the time) on switch so it never shut off. There was only one wire run to it. :confused: He just left the bulb out. After I ran a ground from the light to the front terminal on the switch and put the bulb in it worked correctly.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#99577 03/03/2007 9:24 PM
Thanks all....I will let you know what I discover next week when I can get back in the garage.EB.
