1 members (Bucker),
150
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Looking to paint my 1949 cape maroon. It was not the original color, but I want to keep it close to original, so I'm going with an originally offered color. My question is does anyone have a truck that is painted in cape maroon? I've seen chips, and pictures of maroon trucks on google. But I'd like to see one that is painted "Cape Maroon" using the offset codes that are available through the stovebolt tech tips.
Or if anyone has any similar maroon colors that would be found on a later model production vehicle that would be very similar. | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | I did a search from the menu above for "Cape Maroon" and came up with a lot of posts about this color. Maybe this search link will work. Anyway ... you should follow up with some of these folks. Maybe a PM if they haven't posted in a while. Good luck, Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Saw an early '50 or '51 Studebaker Starlight couple this past summer, thinking it was the "Commance Red", Wife like it,was more of a brown maroon, not too much red in it like the Cape Maroon. I have a pint of the Cape Maroon from the PPG dealer, according to the formula when I called PPG. (she says it't too reddish) Have yet to actually spray it on metal | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I think I may just have to pick a maroon that is going to be on a new car lot and use it. Most of the google image searches will just say maroon, so no clue if they are cape or another flavor. At least I can see it without having to drop $400 on experimenting with colors. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | This is my issue, finding a maroon that is either 1) accurate to the original, or 2) the right maroon for my eye. That picture is too red/orange. I want a deep maroon. Found a modern color that I like, its just that its a metallic. Not sure if they can just mix it without the metallic or not. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | check out the '49 chevy passenger color "Oxford Maroon", seems to be less red, more brown maroon. Mike | | | | | Joined: Nov 2009 Posts: 5 New Guy | | New Guy Joined: Nov 2009 Posts: 5 | 1961 corvette hondoris maroon. If I knew how to down load a pic. I would. Just google it. I think it is what you want. Was used way back in the early 30.s and up. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | In case you are interested in seeing old paint chips of Cape Maroon, a few are linked-to near the top of the Tech Tip for Paint Codes 47-55 Advance-Design Trucks: Acme - PROXLIN chip Ditzler/PPG chip At the bottom of that Tech Tip is information on how to contact PPG. You might get lucky and they might give you the name of a modern "offset" code/name/formula. As you most likely know, old chips (and old trucks, and scanned old chips, and computer screens) would display colors that might not be true to the original non-oxidized, non-aged, paint color. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I found the color that I want. This color right here. I am working with Alexander Auto who is/was selling the particular truck to see if maybe I can get lucky and get an offset code or a modern color. To me, it is my "ideal" maroon. Ideal color maroon for my truck | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I LIKE the way my truck turned out!! I bought a gallon of Van Sickle Premium (Alkyd)Implement "Farmall" Red,NOT Case I.H.C.,(which is more orange). I added a little less than 1/2-pint of Van Sickle Premium Gloss Black,to get the shade I desired. Check my truck out,and see if it's the shade you're looking for!! Total cost for the paint, primer,and reducer was about $125.00!! I'm planning on using Van Sickle clear coat,to finish it off,since I added a little too much reducer. It's a little dull,for my taste. The clear coat should help bring out the shine,as well as give a protective coating. Hope this helps!!
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Aggiejon I saw a car at recent show that I liked the maroon color. Owner said it was a 1989 Chevy truck color so maybe you can check w. Paint supplier. Course we Ags are partial to maroon WHOOP
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Just saw a 2014 Honda Pilot at he dealer this week, the color is Dark Cherry Pearl, nice and dark maroon, which will probably be my choice of color. Mike | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Aggiejon I saw a car at recent show that I liked the maroon color. Owner said it was a 1989 Chevy truck color so maybe you can check w. Paint supplier. Course we Ags are partial to maroon WHOOP Yes sir. My jeep is painted maroon. paint shop used a Century Club sticker to match to. turned out too purple to me. Its ok, but it looks better w/ mud on it, which is how it stays most of the time. But this truck won't get dirty, so it has to be right on. This is a long term project so I'll try and find something a little more modern that works. Problem w modern is they are all metallic. not sure how a paint forumlated for metallic would work if mixed for non-metallic. Gig 'em! | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Dunno how long Barrett-Jackson keeps a page active, but this Cape Maroon just sold in Phoenix for $44K. Looks exactly like the truck on the cover of Tom Brownell's original edition of "How to Restore Your Chevrolet Pickup." (posted for reference, as it appears OP has long since painted his truck) I saw that truck in person at a show in the early 1990's and the only word I can think of is WOW!
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Dunno how long Barrett-Jackson keeps a page active, but this Cape Maroon just sold in Phoenix for $44K. Looks exactly like the truck on the cover of Tom Brownell's original edition of "How to Restore Your Chevrolet Pickup." (posted for reference, as it appears OP has long since painted his truck) I saw that truck in person at a show in the early 1990's and the only word I can think of is WOW! That's the color I'm in love with. OP is still working on it. A slow process. But I'll get there eventually. | | |
