| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | I just put a 350 short block with automatic I need to put in a new radiator any suggestion on a good supplier close to Kentucky for freight
Bob May
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | For a reasonable-facsimile thereof, as compared to the factory-correct Harrison 3-core or 4-core V8 radiator, check with a radiator shop in your area. There are typically more economical, than the fast-good auto parts suppliers, in most cases.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Try O'Reillys Auto Parts. Don't forget to get a 350 fan shroud and upper and lower radiator mounts!
Best wishes,
Les | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I've always taken the radiator to a radiator repair shop. They can just flush it or re-core it if need be.
Lower Radiator Mounts, there are lower radiator mounts? Maybe that's why my radiator moves around a bit. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Thought it only had a giant core support?
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There are two lower radiator cradles with rubber cushions, mounted to the top flange of the radiator cross member (V8) and on the upper flange of the radiator cross member (6-cylinder), via hot-bucked rivets from the factory. The upper radiator hold-down bracket and lower cradles, are radiator-specific, to properly & firmly secure the radiator position. The radiator does not physically attach to the radiator support or the fan shroud extensions.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I didn't mean to stir up unrest but I replaced the original radiator in my 1969 panel with a new, all brass Harrison that I found at a local O'Reilly's. They told me that it was a regular catalog item and the price, somewhere around $125 was standard. There is a tag soldered to the top of the back of the upper tank that says "Harrison" and it is a 4 row. I bought it because it was $50 cheaper than the stock 6 cylinder single row radiator! I had to replace both the upper and lower metal mounts and the rubber inserts in both. I added a 350 fan and fan shroud to complete the cooling system. With a 190 degree thermostat that's where the gauge sits, running hard or long idle! This was my goal.
Les | | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | Thanks for the info guys I took it to Romple radiator shop in Louisville to have it repaired and they wanted $473.00 to fix it and I don,T have that kind of green I will try O'Reilly's
Bob May
| | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | You can get a new one for about $250 from several online parts. I think the part number has 284 in it.
I had a local shop do mine and cost was $300. I would buy new if had it to do over.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Since this is the '60-'66 Chevy truck forum, my input is based on these years. not sure about the '67-'72 Chevy truck radiators.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I just put a 350 short block with automatic I need to put in a new radiator any suggestion on a good supplier close to Kentucky for freight Links section here at the 'bolt Look for the parts vendors near you. Links / Services Look under Radiators for specialized services. ---- an online chevy truck pal swears by this company... and they are very demanding about their parts as they had a 4x4 mud truck at the time : Complete Radiators dunno if they carry one or what... call and ask. -W | | |
