10 members (Bill Hanlon, pdlightning, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen),
75
Mod | | | Forums66 Topics128,050 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 62 | '53 3100 1/2 ton with a 12v conversion. the truck currently has a 12v alternator from who know where, but it's not charging. i want to replace it with a 12v generator, but i can't find any place that sells it whole, every place i've looked has a 12v generator without the end plates. this wouldn't be an issue if i was directly replacing something i already had. any ideas? link1 link2 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you're not looking "everyplace"  your 2nd link show 'out of stock', meaning they'll need yours to rebuild, the 1st link [Bowtie] shows a complete generator, plus a core charge, as does Jim CarterBill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You may save some money hunting this on eBay, I bought my 12-volt unit there with a fresh rebuild for $75 shipping was in a large flat rate box for another $15 or so. You will find 70-80 there now. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think what Classic Parts is trying to say is that the measurement for that generator, if they had them in stock, would be made at the case, i.e. 6" long without the end plates, not that they sell the case only without end plates. Immaterial anyway because as Bill points out they're out of stock now anyway. Good tip Brad and don't forget the Stovebolt Swap Meet truck parts for sale. I'm sure there are a ton of those 12v generators laying around because they were traded for an alternator. Don't be afraid of rebuilding a used one if it needs it gmtjr, there isn't a whole bunch to them. DG
Denny G Sandwich, IL
