Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 103 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
#994900 12/26/2013 7:31 PM
I am pulling my 230 engine with the muncie truck 3 speed out of my 63 c10,and putting a 283 in it . I want to put a saginaw 4 speed back in it.What would be the best 1st gear ratio if I am running the 373 gear in the rear?One day I would like to go with a 5 speed but a 4 speed fits my budget for now.
Thanks for your help.
Longhorn
ODSS President
ODSS President
Start here.... then go here. For me, it's all about terrain, I live in the Piedmont region of central Virginia, rolling hills with a mountain pass at 2100ft, lot's of overdrive type long distance driving. Think about how you will use your truck and decide on your ratios and tire size, play with that second site, get in tune with the sweet spot of your drivetrain.
Good luck,
Cosmo
~ Cosmo
1949 Chevy Half Ton
Longhorn, I suggest you heed Cosmo's good advice. I know that I would do so. I'm going to add a bit of my own advice, too. Unless you have a big garage and plenty of floor space, take small bites. That is, do the engine first, then the transmission. As you read here and possibly other places, you may get more ideas. Transmissions can be a fairly easy swap anyway. Take your time! Think! If you get done to fast, you'll just have to get another one!
Best wishes,
Les
Great advice ,I will put my 283 in and go back with the factory non syncro 3 speed on the tree and run with that for now.Would like to go with a 4 speed but the three speed works fine and will give me time to tackle things that dont work now.
Thanks for the great advice.
Longhorn
