8 members (Gdads51, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, Ponchogl, sron48, 1 invisible),
74
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 19 New Guy | | New Guy Joined: Jan 2013 Posts: 19 | I am not very electrically minded when it comes to wiring; however, I bought a brand new harness and plan to "attempt" to wire the entire truck over the next couple weeks. It is a 1956 2nd 3100 and the question that I have right now is...I have the original headlights with wiring and they are in excellent shape. There are three wires coming out of the back of each one brown, black, and green. Which one is which?
I'm also interested in any kind of blogs, diagrams, photos, etc of wiring (esp. original ignition switch and headlight switch). I'm learning and I know that I have a learning curve ahead of me.
Thanks, Schwin | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I would suggest you purchase a shop manual most of the vendors sell them. It has wiring diagrams for everything you could want , and a lot more info for other things you may want to work on later.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | brown =low green=high black= ground + what tommy said | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Or just google "1949 Chevrolet truck wiring diagram". I downloaded, blew up to 11x17, and laminated a diagram just this week. Or find the old car manual project. It has a section by section scan of the Factory Service Manual. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Here is a little sheet I made for my 1956 Chevy 3100 It has the wiring colors and gauge. There maybe be some errors I hope not Its what I created after studying the wiring diagram. I also have a PDF file of the wiring diagram just email me and I will send it to you.
Headlamps………………………………………………………………………………………………………… High Beam 20 Ga. Light Green Light green from “U” on the dimmer floor switch Low Beam 20 Ga. Tan Tan from “L” on the dimmer floor switch Ground 20. Ga Black To the ground chassis Parking/Turning Signal Lights…………………………………………………………………………………... Park Lamps 20. Ga Violet From the “PK” on light switch Horn……………………………………………………………………………………………………………….. Horn 14 Ga. Black From terminal “H” on the horn relay Lighting Switch Assembly………………………………………………………………………………………... Terminal “GRD” 20 Ga. White Plain wire to the dome light Terminal “D” 20 Ga. Orange Ribbed wire to the dome light Terminal “T” 20 Ga. Black To the tail lamps Terminal “BAT” 14 Ga. Red From the terminal “BAT” on the ignition switch Terminal “BAT” 16 Ga. Red To acc. jct. block Terminal “S” 20 Ga. Orange To the brake petal switch stop lamps Terminal “PK” 20 Ga. Violet To the parking lamps Terminal “H” 20 Ga. Light Blue To the floor dimmer switch Headlamps Terminal “PL” 20 Ga. Gray To the 5 instrument lights (3 in the cluster, 1 in the ignition, 1 in the heater control panel, & 1 in the cigarette lighter) Terminal “PL” 18 Ga. Gray To the acc. jct. block Brake Petal Switch ……………………………………………………………………………………………… In 20 Ga. Orange From Terminal “S” on light switch assembly Out 20 Ga. Nat. White To stop lights Floor Dimmer Switch…………………………………………………………………………………………….. Terminal “BAT” 20 Ga. Light Blue From terminal “H” on the light switch Terminal “L” 20 Ga. Tan To the low headlight beams Terminal “U” 20 Ga. Light Green To the high headlight beams Terminal “U” 18 Ga. Light Green To the high beam indicator light in cluster Temperature Gauge In 20 Ga. Pink From terminal “IGN1” to the temperature gauge Out 16 Ga. Dark Green From the temperature gauge to the sending unit Gas Gauge Tank Unit…...………………………………………………………………………………………... Gasoline Meter 20 Ga. Brown Attaches to the bolt on sending unit from the gas meter Ground 20 Ga. White Attaches to screw on sending unit to the ground chassis Stop Lights………………………………………………………………………………………………………… In 20 Ga. Nat. White From the brake petal switch In 20 Ga. Black From terminal “T” on the light switch assembly Cigarette Lighter………………………………………………………………………………………………….. In 16 Ga. Red From the terminal “BAT” on the ignition switch In 20 Ga. Gray To light Ignition Switch……………………………………………………………………………………………………. Terminal “BAT” 16 Ga. Red To cigarette lighter Terminal “BAT” 14 Ga. Red To terminal “BAT” on lighting control assembly Terminal “IGN2” 20 Ga. Dark Green To the coil and resister on the fire Terminal “Start” 20 Ga. Violet To the solenoid switch on the starter Terminal “IGN1” 20 Ga. Brown To the resistor on the fire wall Terminal “ACC” 20 Ga. Pink To flasher Terminal “IGN1” 20 Ga. Pink To gasoline gauge Terminal “ACC” 14 Ga. Pink To the acc. jct. block Gasoline Meter……………………………………………………………………………………………………. In 20 Ga. Pink From the terminal “ACC” on ignition switch Out 20 Ga. Brown To gas sending which attaches to the bolt Instruments Lights 4 lights in gauge cluster……………………………………………………………………. 20 Ga. Gray From the terminal “PL” on light switch Acc. Jct. Block…………………………………………………………………………………………………….. 16 Ga. Red From terminal “BAT” on the lighting switch assembly 14 Ga. Pink To terminal “ACC” on the ignition switch assembly 20 Ga. Gray From the terminal “PL” on the lighting switch assembly Horn Button……………………………………………………………………………………………………….. 20 Ga. Tan From the terminal “S” on the horn relay Horn Relay………………………………………………………………………………………………………… Terminal “H” 16 Ga. Black To the horn Terminal “B” 14 Ga. Red From terminal “B” on the voltage regulator Terminal “S” 20 Ga. Tan To the horn button Voltage Regulator………………………………………………………………………………………………… Terminal “B” 14 Ga. Red To terminal “B” on the horn relay Terminal “B” 12 Ga. Red To ammeter Terminal “A” 14 Ga. Brown From terminal “A” on generator Terminal “F” 20 Ga. Dark Blue From terminal “F” on generator Turning Signal Assembly in Steering Column………………………………………………………………….. 20 Ga. Yellow From the flasher 20 Ga. Dark Blue To the right front turn signal 20 Ga. Dark Blue To the right front turn signal indicator 20 Ga. Light Blue To the left front turn signal 20 Ga. Light Blue To the right front turn signal indicator 20 Ga. Pink To the white stripe wire going to the left stop lamp 20 Ga. Purple To the white strip wire going to the right stop lamp 20 Ga. White To the stop lamp floor petal switch Flasher……………………………………………………………………………………………………………... 20 Ga. Pink From terminal “ACC” on the ignition control switch 20 Ga. Yellow To the turning signal assembly in the steering column High Beam Indicator light in Instrument Cluster……………………………………………………………… 18 Ga. Light Green From the wire attached to “U” on the dimmer switch Coil………………………………………………………………………………………………………………… Positive 20 Ga. Dark Green From Terminal “IGN2” on ignition switch Negative 20 Ga. White To screw terminal on distributer body Ammeter…………………………………………………………………………………………………………... Positive 12 Ga. Red From terminal “B” on the voltage regulator 12 Ga. Black To the battery terminal on the starter solenoid Resistor…………………………………………………………………………………………………………….. 20 Ga. Dark Green To the coil and to the terminal “IGN2” on ignition 20 Ga. Brown From terminal “ACC” on the ignition switch 18 Ga. Brown To the windshield wiper switch Generator………………………………………………………………………………………………………….. Terminal “F” 20 Ga. Dark Blue To terminal “F” on the voltage regulator Terminal “A” 14 Ga. Brown To terminal “A” on the voltage regulator Starter……………………………………………………………………………………………………………... Solenoid Winding 20 Ga. Violet From terminal “Start” on the ignition switch Battery Terminal 12 Ga. Black From the ammeter Battery Terminal 4 Ga. Black From the battery Starter Body 6 Ga. Copper Strap to chassis Battery……………………………………………………………………………………………………………... Positive 4 Ga. Black From positive side to the battery terminal on the starter Negative 6 Ga. Copper Strap Negative side of battery to the chassis Deluxe Heater/Vent/ Blower……………………………………………………………………………………... Switch Red From acc. jct. block Switch Brown To blower motor Windshield Wiper………………………………………………………………………………………………… 18 Ga. Brown From resistor to the windshield wiper motor
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Tiny J, excellent wireing key. Thanks for the time and effort involved.
| | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | LOVE IT! Can I get this for a 41' half ton? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | factory wiring diagrams, most of which have colors and wire sizes shown Bill | | | | | Joined: Jan 2013 Posts: 19 New Guy | | New Guy Joined: Jan 2013 Posts: 19 | Thanks a lot y'all! I'm just now starting to jump on the wiring. This forum has been the greatest!!!
Now, another question. The truck had an alternator in it when I got it with no wiring. I'm not certain of the make or model but it has a 2-spade plug on the side and a terminal in the back. I'm reading a lot about wiring and diagrams. Do I need a regulator of some sort somewhere?
Schwin
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | See if the two prong plug is like this (ll, 90% to the pulley) or like this (=, parallel to the pulley). | | | | | Joined: Jan 2013 Posts: 19 New Guy | | New Guy Joined: Jan 2013 Posts: 19 | Ok here is a link to some photos of it. I'm SO lost when it comes to wiring. I have a Hot Rod Wires wiring harness and am trying to figure this thing out. All the wiring diagrams I have are with the generator, not an alternator. http://s1109.photobucket.com/user/s...roject/IMG_0693.jpg.html?sort=2&o=38
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Ok you have a alternator with an internal regulator. There are a few ways to do this, not knowing what your wiring harness is or how it's marked, I'll basic rundown of one way to do it. There will be 3 wires, a big 10 gauge that is red in color from the battery that connects to the back of the alt. on that stud, you can also loop the small red wire from the plug on the alt. to that stud. the white wire will need to go to the ignition switch, this excites the alt. when you startup and disconnects it when you turn engine off. If the white wire is in the wrong place the engine will continue to run when you turn the key off.
The best thing for you to do would be to contact the wireing harness manufacurer and tell them what you want to do, I'm sure they will be able to guide you through this.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2013 Posts: 19 New Guy | | New Guy Joined: Jan 2013 Posts: 19 | Thanks a lot Tommy. That will get me started anyway. | | |
