0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99414 02/21/2007 2:12 AM | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Having problems with alternator--replaced the old alternator, started truck--now no output on new replacement alternator. 53 Chev converted to 12-Volt system and new wiring harness before I bought it.
Suggestions on how to start checking for the problem?
Need to find a place to start--thanks, T.K. | | |
#99415 02/21/2007 2:27 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | First, you'll want to make sure that things are grounded properly. If that's OK, then make sure that you have power to the B+ terminal at the plug for the regulator. Alternators have to have a signal voltage in order to operate. No power at that terminal, aand the altenator won't work. One more thing, make sure that the battery is fully charged. That can cause a similar problem because the voltage signal to the regulator will be weak. Unlike a generator, an alternator will not recharge a completely dead battery. So it does have to have at least some charge to it to allow the alt to do its job.
Bill Burmeister | | |
#99416 02/21/2007 2:32 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | tk261,
The alternator need a little kick of power before it does its thing. If your alternator is a SI unit, #1 wire needs to see voltage when you turn the key to the ON position. If you are using a older, externally regulated alternator, the 'F' terminal on the alternator should see power when you do the same thing with the key.
With the externally regulated style, you can actually hear the contacts click inside the regulator (firewall) when you cycle the key from ON to OFF.
If you have a voltage tester, you can see if you get power to this wire when you turn the key on.
There is a little hole to stick a dinky screwdriver in that's located in the back of the case. This would only apply to the SI unit. It will ground the regulator (internal) and put the alternator into the "balls to the wall" mode. If your ammeter is working, it should show a big charge.
I don't recall how to full field a external unit, but I'll bet someone does.
In conclusion, the alternator might not be charging because it isn't being told to..OR, your ammeter isn't functioning and it really is charging...OR, the alternator is bum! These checks should help you figure out what is going on.
If you do have a externally regulated alternator, the voltage regulator could easily be the cause of the problem.
Stuart | | |
#99417 02/22/2007 12:01 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Stuart said it well. To full field an external regulated alt. disconnect the connector at the regulator & put a jumper from the red wire term. to the blue one. You should get a fat little spark when you touch it & the alt should charge way over. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99418 02/22/2007 1:20 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Atomarc, What does the term SI stand for? Thanks
#99419 02/22/2007 1:57 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | beltfed, Is this a trick question! I believe it is French, and my bastardization is " S ystem I nternal"..the little solid state regulator is inside. Why Delco-Remy would use a tag like that I don't know. Stuart | | |
#99420 02/22/2007 2:46 AM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I've made my living popping fuses since I was 18 years young and I've lived to retire with never knowing. I will admit that process control and hostile enviroment (nuclear) instrumention was more my bag. Thanks as always. Hey, I wonder if I could interest "The 3100 Rule" in a small nuclear reactor. oh, maybe 25 Kw, instead of that 3/4 hp motor spinning the generator?
#99421 02/22/2007 4:11 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
#99422 02/22/2007 4:47 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill, So much for my French! Stuart | | |
