2 members (walter74, 1 invisible),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 13 New Guy | | New Guy Joined: Oct 2013 Posts: 13 | I'm trying to figure out the driveline in my new to me 53 Chevy 3100.
I went to grease and check all the levels as well as document the parts. I found I have a drive shaft with two universals with grease fittings rather than a torque tube. As Hotrod Lincoln pointed out I've had some major modification done. Now to figure out exactly what I have!
I've got a Rogers rebuilt 216 powering the truck and the following ;
Transmission serial. CBJ 105999. The casting says GM 48 Rear End. HA 0225
Anyone have any idea of what year and what vehicle they came out of ?
Chris And his red 53
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dck54, for me pictures would be easier to identify than casting numbers. | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Can't really tell from the pictures, but, if your engine is supported at the front of the engine and at the bell housing,you're okay. If your engine is supported mid-block and nothing else, you need a rear transmission support. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dck54, the transmission looks like a fully synchronized Saginaw three speed from a mid sixties up GM car or truck. The rear axle is a "twelve bolt" GM originally from a coil sprung truck I believe. There really is no need to support the back of the transmission with this setup, unless you experience a vibration when driving, hope that helps. | | |
