| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#9933 08/21/2003 11:37 PM | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | I remember this topic being discussed in the past, but because it never really affected me I didn't pay too much attention  I recently realized that the lower rubber oil line (coming from the filter) is leaking and I would like to replace it. The engine is a 235 and has a filter with two rubber lines running to it. Is this stock or aftermarket? I really would like to keep the filter, but I'm having a hard time locating new lines. If I decide to remove the filter (at least for the time being) can I plug both holes or would that cut off my oil supply? Any help would be greatly appreciated! (By the way, my truck is really coming along! Sometime soon I will try to post pictures of my adventures  )
Neil 1955 Chevy 3200
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Could be stock (AC) or aftermarket (Fram) and could be from a variety of years/styles. Dealer would install what they had on hand and owners might have installed whatever they found available over the past 50 years. Most of these filter canisters used lines with compatible fittings. Most of the restoration parts suppliers sell these lines. They all seem to sell 14" and 18" pairs. I would prefer to have 14" and 24" pairs. Look for "Oil Lines, Rubber" in the catalog of the sponsor of this site. http://www.americanclassic.com/asp/...;iyear=1954&ytype=to&exyear=1954 Tim | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You should also be able to buy the hoses at an auto part store. Just have the old ones in hand and clean enough to measure.
Fred 52 3600 69 C-10
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Good time to go for stainless braded pressure and return oil lines. Take the lines over to a place that makes hydraulic hoses and ask them to duplicate.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#9937 08/22/2003 11:17 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | If it's close to stock, it'a a bypass and you can plug the lines. An easy way to check it to plug them with standard brass plumbing fittings, then spin the oil pump with an electric drill. You should flow oil everywhere, easily. Good way to check oiling in general, IMHO.
It's *possible* but unlikely that the block was modded for full-flow, in which case you should not plug them.
As noted, rubber oil line from autoparts or mailorder will work, so just go ahead and replace'em....
G | | |
#9938 09/06/2003 12:21 AM | Joined: Sep 2003 Posts: 5 Member | | Member Joined: Sep 2003 Posts: 5 | I went to my local hydralic shop and had them make me a set of lines in the length that I needed. They'll handle alot more pressure than what my little 235 will ever make, but theres nothing wrong with that. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I just returned from the hydraulics supplier with new oil lines for my 261. They are the big ones for full flow and cost $50.48. More than I thought they'd be. NAPA didn't have the fittings. I was thinking about the metal braided ones for protection but I was afraid to ask how much. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I couldn't find any locally, Chevy Duty (or possibly LMC) did have them. They worked fine. | | |
