2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#993060 12/17/2013 3:10 AM
Z
Z Offline
Alright, I'm fairly new at this so forgive me for the errors and lack of knowledge.
I'm thinking a 700r4 transmission with a 4.10 differential in the stock rearend of my '51 3600. I want to use this truck as a "go anywhere" truck. I'm not off-roading or drag racing. I just want to take it down the highway without blowing up. Any thoughts, feelings, opinions? I am open to any suggestions. Thank you for your time.
the 700R4 is a good trans
The .70 OD and the 4.11 rear ought to be a good match.
What tire are you going to run? Tire Rev / mile can be found on many tire sites (tirerack.com)?
BC
1960 C60 pasture art
Cletis #993094 12/17/2013 5:18 AM
Z
Z Offline
does the 700r4 come with overdrive?
BC59 #993095 12/17/2013 5:19 AM
Z
Z Offline
Probably the closest to the orginal size I can. I will probably use 17inch rims.
700r4 is an over drive trans. It's a nice combo with 4.10. Good low end and nice cruising on the highway. What motor is going in front of this set up? Maybe a 3.73 if the motor has enough bottom end. With 4.10 and 31" tire your at about 2200 rpm for 70 mph.
The 4.10 might be hard to dind for the stock differential. Most 3/4 tons of the era have 4.57 gears
What's currently in the truck?
Z
Z Offline
The current gear is 4.57:1. I am told that the 4.10:1 gear can be swapped in the housing pretty easily. Maybe that person was wrong? Anyway I was hoping to put a Chevy 350 in it. I want to keep to carburated power and I thought it would fit in nicely. Again, maybe I am wrong.
Lots of those swaps on here. Sounds fun, best of luck to ya
Nope just auto. Standard would be like a tremec 5 speed. I think there's quite a bit of fab work needed for both swaps, I am not sure.
Z
Z Offline
Actually, in my constant learning experience, I realized that the 700r4 is an automatic (yea, Im still learning) anyone have a thought on the Tremec 5 speed?
Are you building a work truck or a hot rod? I would first define what the expectations are for the truck and then select components.
Z
Z Offline
I probably won't use it to pull anything except maybe a motorcycle trailer. I just want a cool street rod that I can take anywhere.
