| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | Are the 39-40 cabs the same as the 41-46 cabs as far as dimensions go? Thanks
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The short answer is no. The 41-46 cabs are longer in the cowl/firewall area, giving them more leg room. Why are you asking? | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | I was just wondering what might interchange between the two. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What are you looking to interchange? | | | | | Joined: Nov 2010 Posts: 62 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 62 | Nothing right now, I have been looking at pictures of the different years and the 39 and 40 body's look so close to the 41-46 it got my curiosity going. So I guess it's info that might be useful in the future. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The way I learned what interchanges is actually partly by looking through Jim Carter's printed catalog. That might be a good start. There are surprisingly a lot of differences. | | |
