4 members (Otto Skorzeny, Materman, mason86, GRNHydra), 100 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#992890 12/16/2013 2:22 PM
http://www.fordbarn.com/forum/showthread.php?t=125943
Babbitting was a discussion not so long ago. This is a great thread about it, even if its from a Blue Oval site.
Good article- - - -thanks! When I was stationed in Okinawa a local machine shop did a lot of Babbit work, re-pouring various types pillow blocks and other cast-in-place bearings. I used to hang around and watch when I could get time off from fixing the electronics on B-52's. I'm doing a rebuild on a 1928 Model A soon, and it's possible I might have to re-pour the main bearings. A machine shop near my farm has a portable line bore machine so I'll make a mandrel a few thousandths undersize, rough-pour the bearings, and get them to do the finish boring. That should be a lot less time-consuming than scrape-fitting all the bearings!
When my dad poured a brng. he would wrap the mandrel with one layer of newspaper then spiral wrap that with string. This would cast a grease groove in the brng. And no the paper wouldn't burn.
That's a great idea. I bet using a wire would work and you could control the depth by using different diameter of wire.
