| | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Good article- - - -thanks! When I was stationed in Okinawa a local machine shop did a lot of Babbit work, re-pouring various types pillow blocks and other cast-in-place bearings. I used to hang around and watch when I could get time off from fixing the electronics on B-52's. I'm doing a rebuild on a 1928 Model A soon, and it's possible I might have to re-pour the main bearings. A machine shop near my farm has a portable line bore machine so I'll make a mandrel a few thousandths undersize, rough-pour the bearings, and get them to do the finish boring. That should be a lot less time-consuming than scrape-fitting all the bearings! Jerry
| | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | When my dad poured a brng. he would wrap the mandrel with one layer of newspaper then spiral wrap that with string. This would cast a grease groove in the brng. And no the paper wouldn't burn. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | That's a great idea. I bet using a wire would work and you could control the depth by using different diameter of wire. | | |
