1 members (Hotrod Lincoln),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I am trying to assemble everything going through the firewall now that the jambs and firewall are painted in my 50. Does anyone have pictures of their firewall that I could reference? I am most concerned with the upper half - with all the grommets for wires, cables, etc. I have the pedals in. Thanks for any help you can give. I got my truck in buckets and boxes. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I'm sure there are pics available. I'll look through mine to see what I have. But, you should really invest in an assembly manual(and shop manual). They are not too expensive and are just a terrific reference source, especially the assembly manual with all its illustrations, including the firewall.
Drew
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 |
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Jumping in with a question also for Brad. I have seen before the different style 4 hole plugs that you show on the blue and red pickup. What I'd like to know is the time or model the covered style plug(red truck) was used? Was it a certain model item only? I'd like to find a good one some day as I like that style better than just the rubber plug.
Drew
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The early version with the metal cover and grommet was used from 1947-mid 49 when many of the changes common to the 50' model were introduced. It attaches with two large screws and the grommet is coped to fit neatly under it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | your 50 should look like this reference pic ...pic... ...pic... ...pic... ...pic... ...pic... heater hose routing might be a little different depending on type of heater you have I agree with what was stated above. Factory Assembly Manual is very helpful. I don't recall but one of the years had some midyear changes. The firewall stamping was a little different and the fuse box and other changes... maybe 49? | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Thanks for all the pictures guys. I have a manual but the manuals dont show it like these do. Can someone please confirm which 4 wires/ cables come thru the 4-hole grommet? I suspect oil pressure line, throttle and choke but whats the other one? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | DADS50's answer that the temp capillary tube is fourth item through the 4-hole grommet in a 1950 firewall is correct. However, the FAM diagram in his link is for a 1954 firewall, which has different routing than a 1950 truck. I don't know what model year introduced the change. The four items in a 1950 four-hole grommet are > Oil gauge pressure pipe > Capillary tube (temp gauge) > Choke > Throttle (actually, a photo by Denny Graham of an original 1950 firewall shows the four items going through a one-hole grommet) The speedo cable is in a single hole grommet in a 1950 firewall. The two different firewall routings were discussed in this thread. The thread has photos of original unrestored 1950 and 1954 firewalls. > Firewall threadThe 1954 firewall in the FAM diagram shows three items through one of the holes in the firewall of 1954 lefthand drive trucks: > Speedometer cable > Oil gauge pressure pipe > Capillary tube (temp gauge) And it shows two items through another hole in the firewall of 1954 lefthand drive trucks: > Choke > Throttle - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Timing of this thread is good as I am at the stage of restoration where I am starting to run all the items through the firewall of my '52. My question is how are the wires and speedo cable routed in the three welded on clips down by the headlight dimmer switch? Can't find any pictures on the web that show this area. Anyone? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Bookmark Denny's site for great AD pictures ...link... ...link... | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Perfect, thanks. I do often refer to Denny's photos, but the site is blocked by my company. Hard to find on my phone.  | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | DavidF Don't know if the speedo cable routing is the same for 1952 as for my 1954. Here are a couple of pages from the 1954 FAM showing the speedo cable on the toe panel below the firewall. Both pages have the same page number ... Sect 12, Sheet 1.001. The two pages show two different types of clips for the speedo cable. (#3699275 and #3704138 / 3703451) I don't know why. > Wiring Harness Clip (1)> Wiring Harness Clip (2)There is a clip support welded to the toe panel that holds the clip for the speedo cable and wiring harness that travel under the cab floor. A tab on the clip pops into a hole in the clip support. I used a clip like #3699275 in the "...Clip (1)" image. > Dual clip for mounting speedo cable and wiring harness onto firewall - American Classic Truck Parts part # FA-113 FWIW, I used this speedo cable: > 70" metal case speedo cable - American Classic Truck Parts part #SPC-2 - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Lonnie:
Thanks. I vaguely remember having two "cables" clipped to the toeboard tab as the FAM indicates (definitely can't remember which style/clip). But, I also was not sure if the speedo cable was clipped into one of the three welded to firewall clips. I see the speedo cable run many different ways on various photos. I also purchased the metal jacket speedo cable as you did. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | DavidF I should have looked at my firewall before I answered your question about the three clips, plus the combo clip for speedo and harness. Can't guarantee that it's correct, but here is what I ran under each of the clips: #1 - left clip = wires to brake light switch #2 - middle clip = wires that travel under the cab and that go through the lower clip with the speedo cable #3 - right clip = speedo cable #4 - lower clip = combo clip for speedo and harness that travel under the cab > photo of the clips on my '54 3104Make sure that the speedo cable doesn't make sharp bends. Massage it a little after you finish to make the bends as long and slow as possible. - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Thanks again for all the color and pictures everyone. 2 tangible questions I have also are:
1) Do you recommend installing the firewall pad(under dash) before after all of the wires, linkages lines are through the firewall or is there a certain sequence of events there? I know pedals and heaterbox need to be installed after but looking for guidance on suggested sequence.
2) How is the firewall pad held to the firewall? My bare firewall has a few rigid looking pins in it but it doesnt look like they come out. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Can you tellus what pad you intend to use? I used this abs pad that has a jute backing ...pic... Something like that will have to be test fitted and trimmed a few times. It comes with pins that hold it to the fire wall | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Thats what mine looks like. It has the jute pad and is fairly rigid. Are the pins plastic or metal and are they just push pins or threaded? There are what appear to be original pins in my firewall but not exactly sure how they should come out. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The firewall/toeboard factory mounted pins are for the rubber floor mat. The ABS plastic/jute firewall cover is held in place with metal "alligator" fasteners (factory). The fasteners are simply pushed through the cover and into factory holes in the firewall. My cover came with the holes/slots already in the cover and they lined up close enough once the cover was trimmed to fit (width). Some of the common vendors sell the clips. Cover retainer | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Just took a look at my firewall pad these are the metal clips that I got for the pad. Same as the link above I ended up not using them | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | So, what did you use to fasten the pad in place in lieu of the factory clips? Did you bolt the pad in place? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yes. After final trim I ran a small bolt and nut up by the wire harness hole and used the fasteners for the Ranco on the other. A have a few picture in this Folder I installed this 3 years ago, I don't recall why I didn't use the clips but I do remember I had the thing out 3 or 4 times trimming | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | OK, I see you did not use the clips at all and you did not use bolts, screws, or any other fasteners. All those empty narrow slits in the photos of your firewall cover are where the clips are supposed to be. If it stays put, then who needs the clips anyway.
Now that I think of it some more, I may remove all the "alligator" clips and use machine screws, washers and nyloc nuts. I think this approach will help stop water and sound migration into the cab from the holes in the firewall that accept the alligator pins. | | |
