1 members (Hotrod Lincoln), 92 guests, and 1 robot.
Topics128,080
Posts1,055,951
Members48,430
8
8 Offline
The PTO cable on my '48 1.5 ton seems a little longer than it needs to be. It is secured in a mount below below the headlight switch on the underside of the dash.
I am curious what length PTO activation/engagement cable others are using?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
I don't think there's any hard and fast rules about this. These cables were usually installed aftermarket, and whoever put it in probably just used whatever was available at the time. If it were mine I probably wouldn't worry a lot about it as long as it works and doesn't interfere with anything.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
J M Offline
If it is to long, you can cut it off to the desired length. Just be careful not to take to much off. That is what I have done with choke cables, throttle cables and even PTO cables.
Jim
PTO knobs I'm familiar with were on the floor next to the shifter. Which would be the signature of the local upfitter. When I first started playing with PTO's, it was a knob and cable. These days it is a dash mounted electric rocker switch.
8
8 Offline
Thanks for all of the responses. My cable is a little long, and like Jim says I can trim it up, I was just curious what length others were using. Mark my PTO knobs are not on the floor, but I don't have one of the electronic switches either. Though there used to be another set of controls for the electric motor powered lift that is currently disconnected but installed on the truck. I don't know which one was installed first, but the PTO driven lift bed was the one connected when I got it.
Has anyone else seen many trucks with both a PTO and electric powered lift bed? My truck was originally a grain truck from Nebraska.
Curt Warren
Salt Lake City
Location of the PTO knobs/cables was determined by whoever installed them, as Mark stated. The location on the left side like Curt has is fairly common. Also on the floor as Mark stated. I have also seen them run through the holes in the dash where the radio knobs would normally go. One of my IH trucks has them there.
Rich
1947 Loadmaster
I bought my cables here. Good place, they have everything.
PTO cables in different length. Just to attach your favorite knob in the end smile
http://stores.ebay.com/wrecker-stor...&_fsub=1021045014&_sid=174848814
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
