| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | The PTO cable on my '48 1.5 ton seems a little longer than it needs to be. It is secured in a mount below below the headlight switch on the underside of the dash. I am curious what length PTO activation/engagement cable others are using? | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I don't think there's any hard and fast rules about this. These cables were usually installed aftermarket, and whoever put it in probably just used whatever was available at the time. If it were mine I probably wouldn't worry a lot about it as long as it works and doesn't interfere with anything. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | If it is to long, you can cut it off to the desired length. Just be careful not to take to much off. That is what I have done with choke cables, throttle cables and even PTO cables. Jim | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | PTO knobs I'm familiar with were on the floor next to the shifter. Which would be the signature of the local upfitter. When I first started playing with PTO's, it was a knob and cable. These days it is a dash mounted electric rocker switch. | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Thanks for all of the responses. My cable is a little long, and like Jim says I can trim it up, I was just curious what length others were using. Mark my PTO knobs are not on the floor, but I don't have one of the electronic switches either. Though there used to be another set of controls for the electric motor powered lift that is currently disconnected but installed on the truck. I don't know which one was installed first, but the PTO driven lift bed was the one connected when I got it. Has anyone else seen many trucks with both a PTO and electric powered lift bed? My truck was originally a grain truck from Nebraska. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Location of the PTO knobs/cables was determined by whoever installed them, as Mark stated. The location on the left side like Curt has is fairly common. Also on the floor as Mark stated. I have also seen them run through the holes in the dash where the radio knobs would normally go. One of my IH trucks has them there. | | |
