1 members (Peggy M), 105 guests, and 3 robots.
Topics128,151
Posts1,057,000
Members48,460
8
8 Offline
'48 Loadmaster 1.5ton 6v, rebuilt motor, generator, distributer, and new wiring harness. Since installing the above items I have let it idle for awhile, and only made short 2-3 mile drives as I am still working on odds and ends. Today I noticed that at idle the ammeter is at center or barely pos or neg, depending if lights or heater blower are activated. However once I rev over 750-800rpm the ammeter pegs almost all the way to negative. Only returning when the idle drops back down below 750 or so. This occurs with the truck sitting in neutral and when driving.
Could this be a voltage regulator adjustment?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
It could be the wires to the gauge are crossed.
One way to check if the AMP meter is hooked up the the wrong way is to turn on the ignition, do not start the engine, and turn on the head lights, if the amp meter swings to charge it is hooked up backwards. If so switch the wires on the amp meter.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Check the terminal voltage at the battery when the ammeter is showing a discharge. If it's 7 volts or above, swap the wires on the ammeter.
8
8 Offline
Thank You everyone for your help, it did not even cross my mind that I might have the wires backwards at the ammeter! I changed the connection last night after trying hippy's suggestion.
One more bug worked out!
Curt Warren
Salt Lake City
