8 members (Robert Crandall, Wheelie, ShopRag, cmayna, baldeagle, Lugnutz, Otto Skorzeny, Hawkman),
49
Mod | | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Horn won't beep.
1948 3100 6 volt system
Horn works when grounding upper column bearing to stealing shaft.
But........no beep when all is together
Got power up to upper bearing. Power goes through contact bushing. But with contact plate on there is no beep. I put on the steering wheel, horn contact bushing, horn contact plate, washer, and nut.
Any ideas?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | My 49 had a similar problem. The large contact disc that the horn cover depresses and makes contact to ground was so corroded that it wouldn't make good enough contact to ground & activate the horn relay. I used a screwdriver and sandpaper to clean it up, works good now. Dave | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | If the set up is like my 52, and I think it is, check the flex, braided connection. Mine had corroded until it quit. A bit of solder and horn honked again.
Steve H
