4 members (55shaker, Peggy M, TS3600, GRNHydra), 111 guests, and 3 robots.
Topics128,140
Posts1,056,467
Members48,441
I will be starting to assemble my truck in January after painting is done. It had an old mopar heating unit under the dash that I'm not putting back in there. Therefore,I have no heating system or parts. I don't mind after market for this stuff. Suggestions will be appreciated. ( all I have is the hole through the cowl and I would like to get the heater back in that spot)
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
Hardshell
Check this out…options for defrost, etc.
Used similar but older unit in a little Jeepster I built and worked great.
Not stock, but should put out the heat you need this time of year!
They are available at various places online so, shop a bit for best price.
http://www.flex-a-lite.com/mojave-heater-3.html
Hardshell Check this out…options for defrost, etc. Used similar but older unit in a little Jeepster I built and worked great. Not stock, but should put out the heat you need this time of year! They are available at various places online so, shop a bit for best price. http://www.flex-a-lite.com/mojave-heater-3.html
The period correct Harrison fresh air heater works great in my 50.
H-02-47
I upgraded to 12 volt motor, switch gives me three speeds, usually only need low.
These are the two correct heaters for a 1950 truck if you are looking to go that way. Rebuilt they are both good heaters and will run you out of the small cab.
http://www.flickr.com/photos/advance-design_parts_co/8129448404/in/set-72157631868452754
Advertise in Swap Meet if you want one, good,rebuildable or driver examples go for $75-150. Rebuilt units or NOS on eBay from $150-$600. There are a couple more parts involved with the Air-Flow retrofit. The recirculating heater has basically 6 two block off plates, switch, vents, and the heater. When new they represented a fairly significant investment, you can see the dealer installed price here.
http://www.flickr.com/photos/advance-design_parts_co/8131119579/in/set-72157631872034068
I had an Arvin recirculating heater in my 52. It would melt the shoes off the Old Lady. I prefer the recirculating type as it seems to eliminate a lot of fogging up of the windshield on cold, wet days.
Carl
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by Squire
Hardshell
H-02-47
that one looks great,
I'll post a pic of the one I have, no idea where it came from
just-a-hacker
'49 3100 before '99
Are u still looking for a heater for your truck
Frank
H-02-47
So that is what the hole in cowl is for, mine was covered.
just-a-hacker
'49 3100 before '99
Moderated by  ndkid275, Phak1
