10 members (SmalltownTRKGuy, Njm, Hotrod Lincoln, walter74, baldeagle, cmayna, Woogeroo, Ponchogl, 2 invisible), 348 guests, and 7 robots.
Topics128,165
Posts1,057,089
Members48,463
#991689 12/10/2013 3:48 AM
0
0 Offline
Got a slopppy yoke on the pinion to my rear axle. As best as I can tell, it can be removed for replacement without disturbing the ring & pinion set up - Am I correct? Also any leads on where I can get a new yoke? Thanks
3B Offline
Hy 03marauderman, the yoke may be o.e.m. p/n 3880670, I can't be sure because my light duty parts book stops at 1968, hope that helps some.
Riding in the Passing Lane
You will not disturb the R&P setup. There is no crush sleeve in that rear end. There should be plenty of used ones around.
1972 Chevy c10 Cheyenne Super
0
0 Offline
3B, Wrenchbender - Thank you both for your input....Greatly Appreciate it....
