5 members (TUTS 59, Rusted Nut, dgrinnan, UtahYork, 1 invisible), 342 guests, and 5 robots.
Topics128,162
Posts1,057,057
Members48,463
#991689 12/10/2013 3:48 AM
0
0 Offline
Got a slopppy yoke on the pinion to my rear axle. As best as I can tell, it can be removed for replacement without disturbing the ring & pinion set up - Am I correct? Also any leads on where I can get a new yoke? Thanks
3B Offline
Hy 03marauderman, the yoke may be o.e.m. p/n 3880670, I can't be sure because my light duty parts book stops at 1968, hope that helps some.
Riding in the Passing Lane
You will not disturb the R&P setup. There is no crush sleeve in that rear end. There should be plenty of used ones around.
1972 Chevy c10 Cheyenne Super
0
0 Offline
3B, Wrenchbender - Thank you both for your input....Greatly Appreciate it....
