Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (tclederman, rfs56trk, Woogeroo, Peggy M, 1 invisible), 48 guests, and 6 robots.
Topics128,010
Posts1,055,299
Members48,419
#99170 02/07/2007 9:55 PM
If your truck is running and the battery is not charging will the truck die when the battery is drained? Here's what happened I was running the truck in the garage(as it doesn't move yet) and yes with the garage door open. It just quit running and when I tried to restart it it acted like the battery was dead. It would not turn over at all. I put trickle charger on it. The next day it started right up as if the battery were fully charged. Any thoughts. :confused:
The crew that works on the \'42 --Sara, Hannah and Abby
#99171 02/07/2007 10:01 PM
shouldn't die with a dead battery [still in the circuit], cuz it will run off the generator, but if the battery is running down that fast, something must be wrong with the charge circuit, like gen not genning or regulator stuck/broke ... and might just have some real poor connection someplace in the circuit, or a short that drains the batt
#99172 02/07/2007 10:13 PM
Will the generator put out adequate voltage when the truck is idling to keep it running if the battery were removed from the circuit?
The little charger must have been on the battery for quite awhile if it were responsible for the new breath of life...either that, or the battery wasn't dead. As my cousin Alphonse used to say, it will develop!
Stuart
#99173 02/07/2007 10:52 PM
Riding in the Passing Lane
Yes it will die. When the battery gets low there is not enough current to fire the coil. If it is a generator it will not charge at slow idle but should charge when accelerated.
1972 Chevy c10 Cheyenne Super
#99174 02/08/2007 3:41 AM
The coil should still fire with as little as 4 vdc applied and possible even less. Haven't tried with less than 4 vdc.
