1 members (55shaker),
42
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99170 02/07/2007 9:55 PM | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | If your truck is running and the battery is not charging will the truck die when the battery is drained? Here's what happened I was running the truck in the garage(as it doesn't move yet) and yes with the garage door open. It just quit running and when I tried to restart it it acted like the battery was dead. It would not turn over at all. I put trickle charger on it. The next day it started right up as if the battery were fully charged. Any thoughts. :confused: | | |
#99171 02/07/2007 10:01 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | shouldn't die with a dead battery [still in the circuit], cuz it will run off the generator, but if the battery is running down that fast, something must be wrong with the charge circuit, like gen not genning or regulator stuck/broke ... and might just have some real poor connection someplace in the circuit, or a short that drains the batt
Bill | | |
#99172 02/07/2007 10:13 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Will the generator put out adequate voltage when the truck is idling to keep it running if the battery were removed from the circuit?
The little charger must have been on the battery for quite awhile if it were responsible for the new breath of life...either that, or the battery wasn't dead. As my cousin Alphonse used to say, it will develop!
Stuart | | |
#99173 02/07/2007 10:52 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes it will die. When the battery gets low there is not enough current to fire the coil. If it is a generator it will not charge at slow idle but should charge when accelerated. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99174 02/08/2007 3:41 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | The coil should still fire with as little as 4 vdc applied and possible even less. Haven't tried with less than 4 vdc. | | |
