| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 42 'Bolter | | 'Bolter Joined: Dec 2009 Posts: 42 | 56 half ton, what grease/oil do you use in your manual steering box, corn head grease or ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 56srw,
This topic comes up fairly often. It sometimes gets a variety of points of view an oil/grease concoctions.
John Deere Corn Head Grease is close to the grade of self-leveling grease originally used by GM.
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Corn head grease is good. my old box had oil in it and it leaked, with corn head so far, after 6 months, no leaks | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I'm going to get that! I was told to use STP. Seems a little extreme to use an oil treatment as the be-all, end all. If this is a vegetable oil as the name implies, I wonder about its longevity in the environment it will be used in.. hot/cold etc. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I got a chuckle out of "If this is a vegetable oil as the name implies,...". A corn head is a gear box on a piece of farm machinery. I can see how you might have been misled. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'm going to get that! I was told to use STP. Seems a little extreme to use an oil treatment as the be-all, end all. If this is a vegetable oil as the name implies, I wonder about its longevity in the environment it will be used in.. hot/cold etc. I can't tell if you are joking or just misunderstanding the Corn Head grease name. John Deere Corn Head Grease - video | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | LOL! Everybody knows a corn head is a hippie dude that smokes cornsilk, right? Jerry
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I know right! Next thing ya know, you are wondering around behind the little animals! | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | CV Joint grease is basically the same stuff. I've read on other forums people using it too. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | The steering box in my '55 2nd series 3100 was nearly empty when I checked after buying the truck. I filled it up with gear oil, and it all ran out on my drive way in a couple of days. Then I had the bright idea of using STP. It ran out on my driveway, just took a little longer. And it made the truck steer very hard. Also when driving the truck the steering would take a set and I would have to keep correcting all the time especially in turns. Then I read about JD cornhead grease here on Stovebolts, and got some from our local dealer in Riverside. Fantastic stuff! It does eventually work(very slowly) its way out my worn steering box bushing and seal, but I can live with that for now. The truck steers and drives so much better with the cornhead grease. It is very slick, Great stuff. $4 a tube, use your regular grease gun and pump it in. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Ima go down to JD and ask for Corn Head. I sure hope I don't get something I didn't expect, but sounds like the best solution.  | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | How many tubes do you need to fill the box?
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | When I filled my steering box with cornhead grease, it took a few times, filling to the top each time. The grease takes a while to flow down into the nooks and crannies and work its way into the balls and ball nut. I checked it a day or so apart, and I think I added grease 3 times. I have not used up the first tube yet. I think I'll go out and check it again! | | | | | Joined: Dec 2009 Posts: 42 'Bolter | | 'Bolter Joined: Dec 2009 Posts: 42 | finally pumped a whole tube of grease in steering box, feels like power steering now, but bump steer all over the place | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | My truck had lots of issues with the steering when I got it first driving. Bad bump steer and even death wobble..... Steering box out of adjustment, no grease in steering box, worn loose wheel bearings, worn out tierod ends, excessive toe out, loose steering arm joint, and 10in wide rims on the front, and to top it off a tiny aftermarket steering wheel. What a disaster! When I had fixed all these issues, and then fitted a steering stabilizer, now my truck drives and steers great. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | FYI, Bump steer is a suspension / steering geometry problem. If interested Google bump steer and you can see diagrams. | | |
