| | | Forums66 Topics128,162 Posts1,057,065 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | Got a slopppy yoke on the pinion to my rear axle. As best as I can tell, it can be removed for replacement without disturbing the ring & pinion set up - Am I correct? Also any leads on where I can get a new yoke? Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 03marauderman, the yoke may be o.e.m. p/n 3880670, I can't be sure because my light duty parts book stops at 1968, hope that helps some. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will not disturb the R&P setup. There is no crush sleeve in that rear end. There should be plenty of used ones around. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | 3B, Wrenchbender - Thank you both for your input....Greatly Appreciate it.... | | |
