Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Otto Skorzeny, 68ironhead, 3B, Waveski, Bill Hanlon, 1 invisible), 133 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#991310 12/08/2013 3:59 AM
I
I Offline
Has anyone replaced the ring and pinion on a 1940 1 1/2 ton?
Is this a tough job with the closed driveline?
Why do you want to replace it. If its a spiral bevel, they are noisy by nature, but will run forever if you keep lubricant in them.
If you have not done a R&P before this should not be your first one. I'll explain a little more. Be it on this rear end or one out of a Mustang you have to get everything set correctly. This is a must. Correct pinion depth, correct ring gear location, etc. If your going to try it for the first time.... Try it something that parts are cheap and available for. Not a 63 year old heavy duty truck!
I have done around 6 R&P's in the last 15 years. It always takes a lot more time than I think. I can imagine that there are enough big truck shops in California that could handle this job and take the worry out of your head as to if it is done correctly.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
