Brrrr
place holder
3 members (Hotrod Lincoln, Bill Hanlon, Rich'sToys), 114 guests, and 1 robot.
Topics128,274
Posts1,058,430
Members48,489
#991474 12/09/2013 1:46 AM
Found a pair of these that are 8.5x17 10 ply. They have the tall, narrow look I want but not sure they would work in a truck application. The tread style is similar to the non directional military tires and the sidewalls look like the classic old bias tires with the diamond pattern on the sidewall. Would they be worth pursuing?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
I would not use them whatsoever.
First off, commercial/agricultural tires aren't meant for high speeds. They'd probably overheat and blow apart.
Secondly, They usually only run about 15 psi of air in them.
Third, they are made to flex. I would imagine in a turn they would be very unstable.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Good point. I found out they are radial too which wouldn't work for me. All I've found is a Tornel tire from Coker that fits my application. They have a traction and highway tire that are 34" tall. My other option is to ditch the 17" split rims which are in great shape and use some 16" tires on a set of modern rims I have. Just don't get the height I want in 16".
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
See if they're rated for road use and what the max allowable speed is, if that checks out OK I think you could use them. They may or may not wear well if not primarily intended for road use though.
They'll also have a weight rating and PSI on the sidewall, so you could answer that question too.
•1952 Chevrolet 3800 pickup
---All pictures---
You may want to check out 255/85/r16 tires; they are about as tall as 7.50-17's, but a little wider. It looks like you have plenty of room for them on your '46, and I think they'd look real nice.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
Moderated by  Dusty53
