| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Found a pair of these that are 8.5x17 10 ply. They have the tall, narrow look I want but not sure they would work in a truck application. The tread style is similar to the non directional military tires and the sidewalls look like the classic old bias tires with the diamond pattern on the sidewall. Would they be worth pursuing? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I would not use them whatsoever.
First off, commercial/agricultural tires aren't meant for high speeds. They'd probably overheat and blow apart.
Secondly, They usually only run about 15 psi of air in them.
Third, they are made to flex. I would imagine in a turn they would be very unstable.
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Good point. I found out they are radial too which wouldn't work for me. All I've found is a Tornel tire from Coker that fits my application. They have a traction and highway tire that are 34" tall. My other option is to ditch the 17" split rims which are in great shape and use some 16" tires on a set of modern rims I have. Just don't get the height I want in 16". | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | See if they're rated for road use and what the max allowable speed is, if that checks out OK I think you could use them. They may or may not wear well if not primarily intended for road use though. They'll also have a weight rating and PSI on the sidewall, so you could answer that question too. | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | You may want to check out 255/85/r16 tires; they are about as tall as 7.50-17's, but a little wider. It looks like you have plenty of room for them on your '46, and I think they'd look real nice.
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | |
