4 members (artinva, Shaffer's1950, Chip O, Rich'sToys), 113 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#99129 02/06/2007 2:00 PM
Hi Guys,
On my 59 it never had a factory turn signal so I bought one from Jim Carters and it works fine, HOWEVER I really would like to have the factory type turn signal.
Can I take one from a "parts Truck" and attach it to my Steering column? If so do I need to alter the column itself in any way?
CLiff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#99130 02/06/2007 2:06 PM
piece of cake - if you have the complete unit including the cup, all ya hafta do is pull the wheel and put the cup on the column, slip the wires down and out the side at the dash, hook the wires to the plug that should be there - like so ... and if ya need the parts, someone here will have the ones you can't get new grin
#99131 02/06/2007 6:48 PM
Also, check your steering wheel. You'll probably have to add the cancelling cam to it.
#99132 02/06/2007 7:06 PM
The switch, lever, and cancelling cam are available new from any supplier. Try searching the salvage yards. Seems that about 1/2 of the TF trucks I see in salvage yards have factory turn signals, especially '56 and later 1/2 tons.
Bill Burmeister
#99133 02/08/2007 9:32 AM
Thanks guys Ill let ya know how it goes.
Cliff59
#99134 02/09/2007 12:26 AM
While you are in there Cliff, you will need to replace the top bushing with one that has the ground wire on it..
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#99135 02/10/2007 6:50 AM
Quote
Say what? :confused: There is no bushing on a stock turnsignal unit.
#99136 02/10/2007 7:59 AM
grin no, but one on the column .... OTOH, if the horn works, I think he'll find that "ground wire" is fine grin
#99137 02/21/2007 11:08 AM
Charlie in two weeks it should be getting a little warmer. Im ready to pick up the signal.
Ill call you but Robin and I are going to Kansas to see her Mom.
again ...thanks
Cliff
#99138 02/21/2007 8:05 PM
OK, Cliff. I'll help you wire it in.
