| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99129 02/06/2007 2:00 PM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Hi Guys, On my 59 it never had a factory turn signal so I bought one from Jim Carters and it works fine, HOWEVER I really would like to have the factory type turn signal. Can I take one from a "parts Truck" and attach it to my Steering column? If so do I need to alter the column itself in any way?
CLiff59 | | |
#99130 02/06/2007 2:06 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | piece of cake - if you have the complete unit including the cup, all ya hafta do is pull the wheel and put the cup on the column, slip the wires down and out the side at the dash, hook the wires to the plug that should be there - like so ... and if ya need the parts, someone here will have the ones you can't get new Bill | | |
#99131 02/06/2007 6:48 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Also, check your steering wheel. You'll probably have to add the cancelling cam to it. | | |
#99132 02/06/2007 7:06 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The switch, lever, and cancelling cam are available new from any supplier. Try searching the salvage yards. Seems that about 1/2 of the TF trucks I see in salvage yards have factory turn signals, especially '56 and later 1/2 tons.
Bill Burmeister | | |
#99133 02/08/2007 9:32 AM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Thanks guys Ill let ya know how it goes.
Cliff59 | | |
#99134 02/09/2007 12:26 AM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | While you are in there Cliff, you will need to replace the top bushing with one that has the ground wire on it..
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#99135 02/10/2007 6:50 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | you will need to replace the top bushing with one that has the ground wire on it.. Say what? :confused: There is no bushing on a stock turnsignal unit. | | |
#99136 02/10/2007 7:59 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  no, but one on the column .... OTOH, if the horn works, I think he'll find that "ground wire" is fine Bill | | |
#99137 02/21/2007 11:08 AM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Charlie in two weeks it should be getting a little warmer. Im ready to pick up the signal.
Ill call you but Robin and I are going to Kansas to see her Mom.
again ...thanks
Cliff | | |
#99138 02/21/2007 8:05 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK, Cliff. I'll help you wire it in. | | |
