8 members (BC59, David Bush, MikeE, Bucker, MickeyP, Rexville48, dt235sd, Forty9),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99117 02/02/2007 10:30 PM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | ok I'll start by saying I dont know crap about electrical. But my problem is I have now power at my fuse box, no headlights, tail lights, wipers, etc. My starter switch works but that because I wired another way. Any suggestions on where i should start would be great. Thanks | | |
#99118 02/02/2007 10:53 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get a test light & a wireing diagram & start traceing. You will know a lot after you get through. You might mention the model truck you have. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99119 02/03/2007 11:27 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Depending on the truck you have - but - most likely your headlights and tail lights don't go through the fuse panel but come right off the light switch. Headlights go through the dimmer switch first. The wipers need to have the key turned on, then look for the fuse and test with a test light. Like Wrenchbender says, get a test light, and a wiring diagram. Connect one side of the light to a good ground and touch the probe to the spot you want to test for battery. If the light lights, it's there. | | |
#99120 02/04/2007 1:31 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | My truck is a 64 C10, I'll give it a try, but my problem is the wiring on this truck is a mess, the previous owner pretty much went crazy under the dash, it doesnt even have the high beam switch, and the high beam indicator shows its on. But I'll give it a try. Im hoping its just the power to the box, because I had no power to the starter switch from the box, so we'll see. But right now Im doing one thing at a time, I just got done putting my Hurst ratchet shifter in, but tomorow I will attack the the electrical. | | |
#99121 02/05/2007 12:10 AM | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | One thing I was taught years ago and it applies to lots of other things besides electrical is think of your current like water flowing through a hose. It has to start and end somewhere and you just have to follow the flow starting at the source. I know sometimes that is easier said than done, but it has saved me from being stuck troubleshooting more than once. | | |
#99122 02/05/2007 12:23 AM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | if your wiring is all tore up, you should be able to find a decent harness in a wrecking yard, they are not that hard to get out.... putting it back is another story..
#99123 02/05/2007 9:09 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You do know that the dimmer switch is on the floor, right? | | |
#99124 02/05/2007 10:18 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | As a follow up, I would assume I had power from the light switch to the dimmer and that the dimmer switch is operational, or the high beam indicator wouldn't be on. That would mean that your headlight problem was in the wires between the dimmer and the lights and any connectors or a poor ground from the battery to the frame and body or a poor ground in the headlight buckets. You apparently have a good ground to the engine ot the starter wouldn't work. Don't attack the wiring, use some finesse. | | |
#99125 02/06/2007 12:24 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | Yeah I know the starter switch is on the floor, but its not there at all. And my starter switch has nothing to do with the fuse box, because I re routed it so I may move the truck. Right now the head lights, tail lights, turn signals, dash lights, wipers, horn and dome light dont work. My motor sergant is going to give me a hand so hopefully I can get it figured out. I wish the wiring was like my 65 Impala, it would be so much easier. oh well. thanks for the help though. | | |
#99126 02/06/2007 6:04 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Not the starter switch. The DIMMER SWITCH is on the floor to the left of the clutch. | | |
#99127 02/07/2007 4:19 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | Yeah no dimmer switch, the previous owner did alot of crazy things. but ill figure out, i just got be patient with it, which is hard for me. thanks though | | |
#99128 02/07/2007 8:45 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You mentioned on another post that it had a more modern steering collumn, maybe the dimmer switch is the turn indicator stalk. | | |
