Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#990941 12/06/2013 4:18 PM
Forgot to write something down again. Replaced the upper steering column bearing on my `59 Chevy 1/2 ton. Where does the tan wire from the bearing plug into? I don't see a stray wire hanging under the dash, so it figure it mush go to a switch or fuse block.
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #990947 12/06/2013 4:44 PM
The wire coming out of the column completes the ground at the horn relay. It does not go to the fuse block. The horn button is the switch.
olddaze #990948 12/06/2013 4:48 PM
So, all I need to do is ground that wire?
olddaze #990954 12/06/2013 5:00 PM
No, it goes to the horn relay. When the button is pushed it grounds the relay.
olddaze #990961 12/06/2013 5:10 PM
Found it. I had the other half of the plug tucked above the e-brake handle.
