0 members (),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 36 New Guy | | New Guy Joined: Oct 2013 Posts: 36 | Hello I have a 1941 1/2 ton pickup with a 1940 216 engine and 4 speed trans. My 40 block has a 3 inch freeze crack that seeps antifreeze. A friend of mine has a 1946 engine with the bell housing, flywheel, Clutch, head and oil pan on it. He said the water pump and rocker assembly is missing on his. I haven't seen the engine yet and he's not sure if its a 216 or a 235 block. My question is is it possible to swap out the two engines and still use the original 4 speed trans? If the other engine is a 235 will that go in my 41 with the 4 speed trans? Here is a picture of the 40 engine I removed from my truck. http://i975.photobucket.com/albums/...c-4a00-b529-2694492b2448_zpsa6be24c2.jpgThanks for the help guys! Tom | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the 46 has a truck bellhousing on it you can use it and your 4 speed will bolt right up. If not just use your bellhousing.
It makes little difference if it is a 216 or a 235. Later 235's are not drilled for the front mount, and 1955-62 engines will need water pump adaptions. 1960-62 engines dropped the throttle pivot position needed. All easy fixes.
See the USA in your vintage Chevrolet! My Blog | | |
