8 members (32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50, Forty9, DadsFirstPickup),
133
Mod | | | Forums66 Topics128,049 Posts1,055,658 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Last week I bought the floor mat at the Truck Shop in Orange, California. Today I put it in. The cutouts are correct and it fits perfect. I can't be happier. This truck has fought me every which way before.
One question. I have a 1948 3100 and the battery is under the floor. Do I put my cutoff at the starter or has anyone found a way to get to the battery and have a nice floor?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | The parts suppliers,(L.M.C.,Jim Carter,just to name a couple,:see "Links") offer a battery "drop-down" box. I'm not sure how difficult it would be to access,with battery under the floor. Seems that it is designed for that application,though. I don't recall seeing too many pick-ups with battery boxes bolted to the outside frame rails,(behind the cab),as is quite common on bigger trucks.They have more space for fuel tanks,tool/battery boxes,etc. Hope this helps. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my 52 had the battery under the floor, I installed a cut off switch mounted to the fire wall and high enough that it was hard to see the switch control that was inside from out side of the truck plus if you needed a boost you did not have to bother removing the batter from the box
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Last week I bought the floor mat at the Truck Shop in Orange, California. Today I put it in. The cutouts are correct and it fits perfect. I can't be happier. This truck has fought me every which way before.
Thanks, The 48 used the lower windlace retainer that screws into the side of the rocker panel, which allows you to tuck the mat under it (though not factory correct) without having to remove any screws. It helps to pry up on the inside edge of it to gain some extra clearance for easier tucking of the mat.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Carl. That's what I have. I didn't know the mat would slide in and out - from under the wind lace retainer. It looks nice on the drivers side
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Fred. I like your battery cutoff idea. Thank you
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If the part in question ("step plate" or "strips that are used for the door seal") is the "lower windlace retainer", here are some photos that give a little idea of differences during Advance-Design years: 1947 to mid-year 1949 - stainless steel 1947 to mid-year 1949 - steel mid 1949 to 1955-1st - stainless steel mid 1949 to 1955-1st - steel I am assuming that the lower retainer changed when the style of door windlace channel guides changed sometime in 1949? (Classic Parts does not give the impression that the lower retainer changed when the door-surround-guides changed). | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Brad, I like your battery hold down. Steve | | |
