| | | Forums66 Topics128,022 Posts1,055,269 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Hi all. Working on 54 3100 with 235 6v. In process of doing a full tuneup and I noticed the new coil I bought (NAPA part # ECH IC7) is marked "Use with external resistor". There was none on the old coil. Not sure if I need to add a resistor??? My electrical "knowledge" is some where between caveman and 2nd grader  so any help/advice would be welcome. THANKS!! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 54hydramaticFL, six volt coils do not need external resistors, are you sure the coil is a six volt coil? Perhaps they put the notation on the coil in error, hope that helps. | | |
