4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#987606 11/21/2013 1:17 AM
On my '42, the previous owner converted to 12 volts and added electric wipers. Some time ago, I acquired both the right and left wiper motors, as cores. My neighbor just recently restored them and got the motors running, so I am looking at reverting to vacuum wipers. After removing the interior sheet metal over the window, I don't see any brackets or other mounting structure, and I don't see where such a thing would attach on the motors themselves. Do the motors mount with just the exterior shaft nut, or am I missing something?
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Yes they mount by the shaft.
GWWirth,
Thanks for confirming how they mount. I see in your photobucket that you have electric wipers, with original looking knobs. Looks very nice.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Thank you. It was hard to find 6V motors. The Vac. ones are OK but they stop under acceleration. They make a fuel pump/vac pump. This is what I would use if I stayed with the vac wipers.
GWWirth #988856 11/26/2013 7:03 AM
Hey GW, Where did you find those wiper motors for your 46? I would like to replace my vac unit with 12v.
Thanks, Chris
scgck #988857 11/26/2013 7:15 AM
I will have to look back through my records. But the challenge was the 6volt issue. I think you can find several 12volt designs. They make them with a connecting arm too. As I recall like 350.00 for the 12volt connected arm ones.
GWWirth #988996 11/27/2013 1:22 AM
I bought 2 ea 12 volt from an Ebay supplier but called and got them a little cheaper direct, thinking about $120. Haven't install yet but existing hole needs to be drilled out to maybe 3/8 or 7/16ths, shafts are long and will need to be cut and they will need to be wired together or switched separately. They came with arms and wiper blades but blades are a little cheap. Unknown if they are still in business web address and phone off box www.rodtiques.com 781-826-2360 Hope this helps. Have fun and good luck
Dan
Chev4t6 #989027 11/27/2013 3:42 AM
Thanks Dan, I've used that kind of wiper on a old jeep I had and was not happy with the quality. I found a kit from a marine company and am looking into that possibility. The company is called Ongaro Marine and the kit # is 31011. I'm not sure if it will fit in the same place as the vacuum unit.
Chris
Speedway Motors has that same wiper kit with a black motor for $29.99. You have to cut the shaft to length.
Harold Wilson
41 Chevy 3/4 Ton
I got the stainless ones from Speedway so that I could use them with a dash switch to control both wipers. They work very well.
My 46 GMC on Photobucket
The 6 volt wiper motors are part number WW349 from Jim Carters $135.00 total included arms and wipers. I had to remove the black cover and remove the switch to get them to fit. I also took old vac. motors and used the switch knobs to keep it org. looking.
Has anyone tried this 6V kit?
http://www.amazon.com/Omix-Ada-1910...1&keywords=6v+windshield+wiper+motor
I think it has an 8" arm & 9" blade.
I'm thinking of trying the replacement arm/blade set on my vacuum motors.
http://www.amazon.com/Omix-Ada-1910...4&keywords=6v+windshield+wiper+motor
It's for a 1/4" shaft and has a better spring in the arm. I'm hoping it will keep the blade on the windshield better than the original ones.
Harold Wilson
41 Chevy 3/4 Ton
Moderated by  ndkid275, Phak1
