1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | At the risk of sounding "real stupid", did all of these engines have oil filters, because mine doesn't. I've been around and worked on a lot of cars but I've never encountered this.
1952 Chevy 3100 1953 chevy 3100 Hot Rod 1946 Chevy Pickup
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Nope, some do and some don't, all depends on the previous owner(s) and what they wanted. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | An oil filter on a 216 is a waste of money. The place the supply hose and the return hose attach both have oil pressure at them. This means there is very little flows through the filter except maybe at an idle.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | Thanks Brad. I can sleep now!
| | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | Thanks Dave. I learned to drive in a 53 but that part didn't concern me. my only concern was if my Dad was within range of hearing me throw gravel as I took off!
| | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Interesting! So has anyone figured out a work-around to get the oil filtered? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have to both agree with Dave and on this rare occasion disagree with him. While both connections have pressure there is in fact oil moving through the filter. IMHO any filtration is better than none. However adding a filter does not mean you can put off the oil changes.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I've got a filter on my 216, it was on it when I got it so I continue to use it. I understand that it's a bypass filter and as Dave says it probably doesn't filter except when at idle but since I'm useing detergent oil I like that theres "some" filtering going on. I also like that it adds another qrt of oil to the engine which is good in my case as I haven't gotten around to replaceing all the worn & leaky seals yet  . Dave | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Just look at the dipstick. With a bypass filter the oil looks like it just came out of the can. I would use one on any one of mine. The only advantage of a full flow is that it catches any particles before it reaches the engine. Big trucks use both. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | In my search to find one, I see them mounted in several locations, one being right on the manifold. Is there a best location? A match the 41' dealer install? I am going to install one before it goes on the open road. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Since they were added on later the manifold is the most common place. Although military trucks did mount a large can similar to an S-2 on the firewall, passenger side, and route hard line to it.
Filters are still readily available for large and small sized cans. About $7-12 depending where you buy. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | If I were to buy a truck that did not have a filter I doubt I would add one,I would drop the pan and remove the valve and side covers to make sure its clean and then change the oil every 1000 to 1500 miles,not to sound like a tightwad but the filter I get for my 37 is getting close to 15 dollars now and just not worth it for how little it does and how little I drive it. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | An oil filter on a 216 is a waste of money. The place the supply hose and the return hose attach both have oil pressure at them. This means there is very little flows through the filter except maybe at an idle. ??? On all the 235's and 261's I have the bypass return is simply a hole thru the side of the block to dump it back in the pan without any pressure involved. Once when changing oil I forgot to tighten the canister lid any more than hand tight and fired it up. At the rate the puddle on the floor grew I knew mine was moving plenty of oil at idle.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | On splash engines the return hose from the filter is attached to a port that feeds oil to the dippers. I once was pumping up oil pressure on a rebuilt 216 and forgot to install a plug at that port. Needless to say the other side of my shop was well oiled.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | Are there any pictures of a retro fit out there?
| | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | That's interesting looking..
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Are there any pictures of a retro fit out there? Oil filter? <CLICK>
| | | | | Joined: Nov 2013 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 79 | Thanks Tiny. I need to get my engine that clean and pretty!
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's an old, pre rebuild, picture. You should see her now.
