4 members (BC59, JW51, Jack Ryan, Craig /49 Panel), 68 guests, and 2 robots.
Topics128,083
Posts1,056,326
Members48,442
#989053 11/27/2013 5:45 AM
Will the back fenders of a 41-46 1/2 ton Chevy truck fit on the 41-46 1/2 ton panel/burb after the bolt up flange was cut off and cut back to the width of a panel finder.??? Has any one tried ???--lc34--
lc34 #989310 11/28/2013 8:59 AM
This doesn't address your question, but a pair of solid, steel pickup rear fenders is too rare to experiment with. Many hobbyists are searching for rear fenders to replace 'glass fenders installed decades ago. Strongly recommend you consider selling your steel pickup fenders & invest proceeds in another solution to restoring your panel or 'burb
lc34 #989312 11/28/2013 10:59 AM
Miss Church --Thank you for your Strong Recommendation , I to am a hobbyists and trying to find rare back finders for my panel. I must apologizes to you for offending you with my experimenting. I can find truck fenders in my area but panel and burbs are vary hard to find.--Thank you again-- lc34
lc34 #989327 11/28/2013 2:44 PM
not sure about the 41-6 fenders but the 35-6 fenders are not the same shape at the top of the fenders and along the body line to the bottom on the inside. there will be a lot of pie cutting and filling to do to get them close to fitting.. i would try to do a fiberglass fender first to see how it would work. unless the steel fenders are trashed
lc34 #989396 11/28/2013 7:09 PM
person-to-person tranactions should be done in email and/or in Private Messaging
lc34 #990886 12/06/2013 11:49 AM
What we've got here is a failure to communicate
Luke
lc34 #991102 12/07/2013 4:13 AM
I feel your pain Ic34 my rear fenders will take a lot of work for my 37.But what options do we have.Replacements just don't exist. every so often one shows up on eBay for an insane price. And no fiberglass is not an option for me.
1937 Chevy 1/2 ton panel
