3 members (farmallb, DaveV, Peggy M), 47 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#989300 11/28/2013 6:22 AM
Hello.
If someone is familiar with the 216 engine, could you please tell me some information?
On the front of the engine, on the block itself-in the middle-there is a small circular hole that is covered with a plate. It is about 3 inches in diameter. It is below the fan and water pump, but above and to the right of the timing belt cover.
When I look at the cut away diagram in the manual, it looks like this is empty space used as a channel for the cooling system. Is that correct? What is the purpose of this hole and the plate that covers it?
The reason I ask is because as I ran water through the engine, I noticed that my plate had moved so that a portion of it was pushed in more than the rest, creating a gap where water flowed out of...similar to how a choke on a carb would have one side pushed down and the other side up when open (but not as drastic as that!)
Any thoughts or ideas?
Judson
Judson #989301 11/28/2013 6:29 AM
Judson, A picture would be helpful. I just tore my 235 apart and I can't picture what your asking about...
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
RDomeck #989303 11/28/2013 6:52 AM
sure...i will take and link in a few days.
p.s. I was doing a little more research and I think it may be some type of plug...
thanks.
Judson #989350 11/28/2013 4:00 PM
block casting hole plug - some people call it a freeze plug or a freeze-out plug (GM did not call it that)
Judson #989492 11/29/2013 4:29 AM
http://www.chevytalk.org/fusionbb/fbbuploads/1385662673-rsz_pb190072.jpg
Here is the link to the pic on chevy talk. It looks like it is what you are saying, Tim...an expansion plug or something like that.
I guess I just need to pry it out and get the same size one from the local auto parts store...they said you can get the ones that screw in.
Judson #989525 11/29/2013 3:40 PM
Yes, that is the casting hole plug. But, it is not a standard (freeze plug) and must be set in a special manner. My suggestion is to use one of the common parts vendors to purchase the correct plug. Install convex out, set with ball peen hammer by indenting center of plug disk. Sealant around edges prior to installing is good idea as well.
