1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Hello.
If someone is familiar with the 216 engine, could you please tell me some information?
On the front of the engine, on the block itself-in the middle-there is a small circular hole that is covered with a plate. It is about 3 inches in diameter. It is below the fan and water pump, but above and to the right of the timing belt cover.
When I look at the cut away diagram in the manual, it looks like this is empty space used as a channel for the cooling system. Is that correct? What is the purpose of this hole and the plate that covers it?
The reason I ask is because as I ran water through the engine, I noticed that my plate had moved so that a portion of it was pushed in more than the rest, creating a gap where water flowed out of...similar to how a choke on a carb would have one side pushed down and the other side up when open (but not as drastic as that!)
Any thoughts or ideas?
Judson | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Judson, A picture would be helpful. I just tore my 235 apart and I can't picture what your asking about... | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | sure...i will take and link in a few days.
p.s. I was doing a little more research and I think it may be some type of plug...
thanks.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | block casting hole plug - some people call it a freeze plug or a freeze-out plug (GM did not call it that) | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | http://www.chevytalk.org/fusionbb/fbbuploads/1385662673-rsz_pb190072.jpgHere is the link to the pic on chevy talk. It looks like it is what you are saying, Tim...an expansion plug or something like that. I guess I just need to pry it out and get the same size one from the local auto parts store...they said you can get the ones that screw in. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yes, that is the casting hole plug. But, it is not a standard (freeze plug) and must be set in a special manner. My suggestion is to use one of the common parts vendors to purchase the correct plug. Install convex out, set with ball peen hammer by indenting center of plug disk. Sealant around edges prior to installing is good idea as well.
