| | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | On my '42, the previous owner converted to 12 volts and added electric wipers. Some time ago, I acquired both the right and left wiper motors, as cores. My neighbor just recently restored them and got the motors running, so I am looking at reverting to vacuum wipers. After removing the interior sheet metal over the window, I don't see any brackets or other mounting structure, and I don't see where such a thing would attach on the motors themselves. Do the motors mount with just the exterior shaft nut, or am I missing something?
Kent | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Yes they mount by the shaft. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | GWWirth, Thanks for confirming how they mount. I see in your photobucket that you have electric wipers, with original looking knobs. Looks very nice.
Kent | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Thank you. It was hard to find 6V motors. The Vac. ones are OK but they stop under acceleration. They make a fuel pump/vac pump. This is what I would use if I stayed with the vac wipers. | | | | | Joined: Nov 2013 Posts: 10 New Guy | | New Guy Joined: Nov 2013 Posts: 10 | Hey GW, Where did you find those wiper motors for your 46? I would like to replace my vac unit with 12v. Thanks, Chris | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I will have to look back through my records. But the challenge was the 6volt issue. I think you can find several 12volt designs. They make them with a connecting arm too. As I recall like 350.00 for the 12volt connected arm ones. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I bought 2 ea 12 volt from an Ebay supplier but called and got them a little cheaper direct, thinking about $120. Haven't install yet but existing hole needs to be drilled out to maybe 3/8 or 7/16ths, shafts are long and will need to be cut and they will need to be wired together or switched separately. They came with arms and wiper blades but blades are a little cheap. Unknown if they are still in business web address and phone off box www.rodtiques.com 781-826-2360 Hope this helps. Have fun and good luck Dan | | | | | Joined: Nov 2013 Posts: 10 New Guy | | New Guy Joined: Nov 2013 Posts: 10 | Thanks Dan, I've used that kind of wiper on a old jeep I had and was not happy with the quality. I found a kit from a marine company and am looking into that possibility. The company is called Ongaro Marine and the kit # is 31011. I'm not sure if it will fit in the same place as the vacuum unit. Chris | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Speedway Motors has that same wiper kit with a black motor for $29.99. You have to cut the shaft to length.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I got the stainless ones from Speedway so that I could use them with a dash switch to control both wipers. They work very well. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The 6 volt wiper motors are part number WW349 from Jim Carters $135.00 total included arms and wipers. I had to remove the black cover and remove the switch to get them to fit. I also took old vac. motors and used the switch knobs to keep it org. looking. | | |
