| | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Anyone successfully get a Saginaw 4spd to work with the original AD column shifter? I can't imagine it'd be all that difficult with reverse on a cable.
I have a Patrick's floor kit but I'm kinda bummed about losing the 3OTT charm. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, it has been done. Motion Guru documented his on the oldGMCtrucks.com board a few years ago. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Awesome! I'll head over there and dig it up. Thanks! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you can find one, some '60s Chevrolet Vans used a 4 speed column shift. Might be able to adapt the control box to work.
Bill Burmeister | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I was thinking the four forward gears would be on the tree and reverse on a cable. | | |
