| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 15 | Will the back fenders of a 41-46 1/2 ton Chevy truck fit on the 41-46 1/2 ton panel/burb after the bolt up flange was cut off and cut back to the width of a panel finder.??? Has any one tried ???--lc34--
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | This doesn't address your question, but a pair of solid, steel pickup rear fenders is too rare to experiment with. Many hobbyists are searching for rear fenders to replace 'glass fenders installed decades ago. Strongly recommend you consider selling your steel pickup fenders & invest proceeds in another solution to restoring your panel or 'burb
| | | | | Joined: Nov 2013 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 15 | Miss Church --Thank you for your Strong Recommendation , I to am a hobbyists and trying to find rare back finders for my panel. I must apologizes to you for offending you with my experimenting. I can find truck fenders in my area but panel and burbs are vary hard to find.--Thank you again-- lc34
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | not sure about the 41-6 fenders but the 35-6 fenders are not the same shape at the top of the fenders and along the body line to the bottom on the inside. there will be a lot of pie cutting and filling to do to get them close to fitting.. i would try to do a fiberglass fender first to see how it would work. unless the steel fenders are trashed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | person-to-person tranactions should be done in email and/or in Private Messaging
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | What we've got here is a failure to communicate
Luke | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I feel your pain Ic34 my rear fenders will take a lot of work for my 37.But what options do we have.Replacements just don't exist. every so often one shows up on eBay for an insane price. And no fiberglass is not an option for me.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
