3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
Y
Y Offline
I started tearing into my 53 suburban and I found a bunch of broken off rear fender bolts. Is drill and tap the best approach or can you get these nut inserts somehwere?
Marc
If you can save them by drill and tap method or heat is the best way, otherwise you will have to cut and replace the nuts. They are available but it takes time and work to put them in.
Y
Y Offline
Thank you. By the lack of responses I figured that might be the case. I apprecaite it.
Marc
