1 members (J Lucas),
85
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | I notice that most 216's I see have an in-line fuel filter just before the carb. But these engines (for the most part) do not have the glass bowl fuel pump.
Question: We are putting the glass bowl type fuel pump on our engine. It has a screen inside which I assume filters the fuel. Is it necessary to install an inline fuel filter as well? Or does the glass bowl type pump sufficiently filter the fuel?
Thanks in advance
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The glass bowl fuel pump was standard.
The glass bowl filter at the carburetor was an accessory.
Is that glass fuel filter "necessary"? No
I always liked the glass fuel filter because I could see if there was water in the gas.
| | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | The glass bowl fuel pump was standard.
I always liked the glass fuel filter because I could see if there was water in the gas. Great! Exactly the kind of response I was looking for…straight to the point and no bull. One more question: I do not have a fuel filter under the tank…do your answers still hold true knowing that? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Many people like a fuel filter down below - one reason is that it is less messy there, instead of changing the filter over top of the engine? I just put a large drip-catching cloth under the filter, no matter where it is located.
Most filters are not very restricting to the flow, but some people have argued that it should be on the output side of the fuel pump (supposedly there is more output pressure than input suction - who knows?).
| | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | Understandable.
Let me ask this: Is the glass bowl type fuel pump alone (without any other filter) good enough for this engine? I'm curious if the screen thats in the glass bowl type fuel pump filters the fuel well enough.
Reason i ask is cause out of the 3 restoring this truck…I'm alone in thinking the in-line filter needs installed. Not to check for water, but to check for sediment, because we are using original tank. Although thoroughly cleaned, we are using original tank.
Thanks again
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ok…understandable.
Let me ask this: Is a glass bowl type fuel pump alone (without any other fuel filter) a good idea? Does that fuel pump (with the screen) filter the fuel well enough? Reason I ask is cause among the 3 of us restoring this truck, I'm alone in thinking the in-line fuel filter needs to be installed. | | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Many of these trucks operated for decades and hundreds of thousands of miles with no filtration (except at the fuel pump). With that in mind the in-line filter helps to keep the fuel cleaner, provides visual confirmation, they look great, and they are an inexpensive option. My $.02 | | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | my thoughts are that with the alcohol now in most gas there is not much chance of seeing water settle in it unless the gas is so loaded with water that the alcohol cannot absorb anymore. by then it is pretty poor fuel. and though the original bowl type filters have metal screens at the top of them they probably let a lot of fine stuff pass through.( and sometime those have been removed or damaged)- likely a little would only settle out in the carb bowl but eventually could start causing problems I guess.my 61 has a filter housing mounted under the cab and I have no idea if it was original equipment but I did buy a new filter cartridge to put in it. probably as any filter becomes stopped up in the suction side of the fuel pump it would make vapor lock more likely especially in hot weather since the newer gas formulas seem to be pretty prone to that.fuel injection systems seems to handle it fine because they have an in tank pump that runs in the fuel and stay cool with no problem picking up and recirculate all the time to help eliminate problems.that lets the gasoline manufacturers blend some pretty light crappy blends without complaints. what a long winded reply huh? Raymond | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just a light breeze Raymond, now you want long winded.... Unless you've got a new tank and new lines you have a 99% chance that you'll be getting parts of the tank in your fuel system. All of the original tanks that I've seem had some of that four letter word, 'rust' in them and most had a bunch. The screen beneath the glass bowl only takes out the bigger stuff a lot of the smaller crud still gets thru and can cause problems at the carburetor. I feel that both the screen and accessory fuel filter are needed to avoid problems. It bothered me that I was having to clean the screen often, which was after the valves in the fuel pump so I opted for an additional inline filter at the tank outlet. Nothing gets thru to the pump now and I just change the inline filter when I do a grease job. http://www.pbase.com/dennygraham/image/141360697With an inline filter before the pump I'd still use the accessory filter at the carb, which would assure that nothing was getting to the carburetor. Besides, it looks like an authentic dealer added accessory. As far as vapor lock, I've never encountered it and I've been driving my stock '50, 216 since '05 pretty regularly without problems. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | Ok thanks a bunch guys. I've been consistently trying to convince the others to put an in-line filter in. And since I'm the youngest...my advice/opinion kinda gets sidelined sometimes. But, on the other hand...if the carb or pump gets plugged up...at least I'll have something to take off the truck and clean or rebuild.  I'll always look for stuff to do on the truck  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh that won't be a problem with these old Stovebolts, there's always something to do in them.
DG
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Here is my 4.8 cent (obama needs the extra for Obamacant) I would rather change out the filter under my truck than rebuild my Carb. Don't get me wrong I have nothing against rebuilding a carb. I would rather be driving my truck. Just for the record I have 3 full filters on my truck. One at the tank, one on the fuel pump and on at the carb.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Political statements are inappropriate here.
| | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | Since we are on the topic of the fuel system. I was curious if anyone has used this product:
http://www.classicparts.com/1947-87-Gas-Tank-Sealer/productinfo/23%2D698/#.UpN_5qVUhGE]
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Sometime in the 1950's, Carter came out with an accessory for their glass bowl fuel filter; it was called a "Magnatrap". This was a small magnet that fit inside the fuel filter. Of course, the magnet would trap any rust particles coming through. When the magnet's color changed from grey to rust, it was time to clean.
This was a very useful device as at the time a lot of the old time filling stations had very rusty tanks.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Lots of people. Some with good results, some with bad. If you can get the tank super clean inside, slosh it and make sure it has a good long time to cure then it renders an other wise scrap tank into a usable one. The bad side is if you don't get it super clean the liner can come loose and plug your line. Personal opinion, if a tank is sprouting pin holes then that indicates to me the it's getting to thin to be safe. I'd opt for a new tank, they taint all that expensive and you can have your FLAPS order one and have it in a few days.
Denny G
| | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Speaking of filters. I have a Carter Carburetor filter (small glass bowl)#2146397, that I'm looking for the filter element, gasket and I think there is a spring use to hold the filter up. I think this is a ceramic element. Can anyone help with where to find , part numbers? I have a part number 2159S, I think this is the whole filter. Another number is GF30-77.
awk | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | on my 52 the original owner over the years had replaced the fuel pump with one that did have have the fuel screen on it so he added an inline glass bowl fuel filter at the inlet to the carburetor. since the carburetor inlet and the horn was in direct alignment he had to bend the horn bracket down at a sharp angle in order to have enough room to fit the fuel filter. when i replaced my fuel tank with a new one it eliminated the rust problems associated with it so i replaced the fuel pump with the correct pump with filter screen, removed the inline filter and moved the horn back to its proper alignment. looks much better. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "Political statements are inappropriate here."
Tim..have a Happy Thanksgiving and lighten up a little. Enjoy others.
